its dependant on which MHZ step size you use on the TM5402HD but the TM is faster from what i can remember of the f3 i owned although later F/W versions could have altered this. ATM the TM5402HD has a flaw in the SW which displays really low SR rates as 45000 which you probably know anyway. you do a good job already m8 with your feed catches
credit goes to the feed hunters not me mate,
i do really want something for myself to start searching,
yea i was reading about the sr issue,
the price difference between the tm5402 and skybox is more then double,
also IMO for any STB over £100 it has to have decent support,
and i think by the looks of it, from what i've read on some forums
some TM owners arent too happy at the moment
im thinking of buying the skybox f5s and invertblack twin or quad lnb
i also was thinking it might be worthwhile to upgrade dish,
which could also help with feed hunting,
i've seen this faval 1.25m dish on eb*y,
the item number is 360352232779
im tempted with it because the size and i can put it on my tm2600 motor due to it being too heavy
anyone had experience with these dishes?
will it be a big improvement compared to my generic 90cm dish?
just to give you an idea im receiving 28.2e to 45w
