Astra 1N @ 28E - about to go on air / on air!!
iggy
PrimeFocus 180cm (Astra 1N) - Inverto Volksbox IDL6651n; MABO 115x128 (80E - 30W) - Dr.HD F16;
EchoStar 80cm (Hotbird + Astra) - Kathrein ufs910.
KRAKOW / POLAND
Ratchet said:
How does it compare with 11127 V at your location? If it's significantly better then this would imply widebeam.
There isn't any sign of 11127 whereas 11165 wants to burn the scale...
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
11165 100% here, but the UK beam should be no problem here too. So doesn't say much about the beam.
C0re
Ede
VU+ Solo SE
Then 11127 is on the UK beam, because both Pan-European beams should be no problem in Poland.
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
Widebeam it is then :D
roberto mafara
Pace 2600C1 DM800HD Vu+Duo
Laminas ofc 1200 triax 1100
Black ultra lnb
BenissaCosta Costablanca
11165 Here in Pedreguer 19.50 db 100% 111127 14.50 93%
iggy
KRAKOW / POLAND
It's not that obvious as polarization H might have different coverage then V. This is exactly the case with Astra 2D.
C0re
Ede
VU+ Solo SE
Of course but that just supports my conclusion that 11127 is on the UK beam. It's a new bird so I expect far less overspill and that's why I think 11165 is on a Pan-European beam. But it's just an educated guess.
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
iggy said:
Is it UK beam or Pan-European one?
There is no way (according to published footprints and various reports so far) the UK beam could reach east Med and the island of Crete with 9.7dB on a 1.10 meter dish...
Btw, no sign whatsoever of 11127 here.
iggy
KRAKOW / POLAND
No question about that, I am convinced :)
who can give result of astra 1n morning and evening if it signal strange
for me 12460h not receiver in mornign only at evening
it posible astra 1n got strong morning ?
Shrubsole
Wintv Nova S2 HD PC card, Quad core PC running DVBViewer on Windows Ultimate. SkyHD+ box.
Folkestone. Kent. England
Interestingly E4HD has currently popped FTA up on:
Frequency : 12324
Polarisation : V
Symbol Rate : 29500
Transmission : DVB-S2
FEC : 3/4
Label : 3843
And it's FTA! (Comes up as encrypted but it's not!) Is it getting ready to hop over to 1N?
i receiver low signal on 5.7c/n 32%
woborny
Frequency : 12324
Polarisation : V
Symbol Rate : 29500
FEC : 3/4
Label : 3843
No signal of this freq using my 80cm dish, but fine on my 1.8m dish (70kms south of valencia)
But 11123 (C4HD) is fine and dandy on the 80cm dish.
Suggesting these two freq use different beams....???
archive10
Interestingly, 11165H is not very strong here in eastern DK.
Only 50 dBuV, with a 6 dB C/B ratio. This is almost worse than 2D levels.
Not sure what is going on. From the footprint stuff I should be getting nearly the same as the UK if on a European-wide beam.
As poland shows strong signal - why not Scandinavia?
Hmm... there's still more to 1N than we might think...
strs65
LNB1: Smart Oxid
Motor: Amiko DM3800
I think it's been turned off or switched to the UK beam. I'm not receiving this frequency now...
Pietclock
125cm
SE Germany 50°N/11°E
it's still there but much weaker... hmm maybe they play around with that 1.3m steerable dish ?
Ratchet
Falkirk
Falkirk
The 11165 H signal is now gone completely here. You may have just caught the tail end of the test as they were winding down. It was easily the strongest signal I have seen at 28.2E (or anywhere else for that matter).
Ratchet
Falkirk
Falkirk
If you're still getting it in Germany it would imply that they are tinkering with the spot beam. Does 1N have more than 1 spot beam ?
Pietclock
125cm
we dont know that ... officially no. However we know the satellite has a 1.3m steerable dish. SES do not confirm that, but you can see it at Astriums homepage.
