Satellite74
- Oct 24, 2011
- Age
- 49
- 80cm oval dish, Invacom single LNB prime focus 28.2°E, generic quattro LNB secondary focus 19.2°E; Technisat SD receiver
- Hanover, Germany
ok so what we can gather from SES's sparse but up to date news is that the new UK spot beam off Astra's 2F satellite will be here later this year.
It appears that both the European wide beam and the UK spot beam will be centered on the British Isles;
will that mean that there will be no frequency reuse between the two beams? After all, if you point two beams practically in the same direction, you would get cross-interference where it is not desired, right?
