Dan Dan
- Oct 8, 2012
- 19/26/28 1m
- tenerife
Huevos said:I don't understand why you keep bashing on about this. The West Africa beam is on Eutelsat's European frequency allocation. Also what beam is stronger in Tenerife has nothing to do with the distance, but the properties of each beam.
whats eutelsat got to do with it ???????????
im talking about the WEST AFRICA BEAM on ASTRA 2F
and im talking about the UK BEAM on ASTRA 2F
that if they REUSE FREQUENCIES then it makes sense they will use the two farthest apart beams ie west africa and the uk
which are 4500km apart
LONDON TENERIFE 3000KM (45 cm dish req)
SENEGAL TENERIFE 1500KM (60cm dish req )
less then
london madrid 1800km .....
and you are saying you would put you hand in your pocket for a 4.5m dish knowing that the beam HALF the distance from the one you want to pick up is using (or can use) the SAME FREQUENCIES
its MAD !!!!!!!! Mutual assured destruction ... NO ONE IN THE ISLAND IS GOING TO UPGRADE THE DISHS WITH THE POSSIBLY OF REUSE .....
If i am pointing at 28e and its the same freq for a english channel and a ghana channel then im going to get the english channel even if its TWICE the distance away ?????
ps the JPEG from SES says it is UK BEAM FOR ASTRA 2EFG ...so same beam on the three new satellites
from - http://www.ses.com/11572422/120522_CDO_Investor_Day_FINAL
SES Satellite Fleet Development
Capacity for Africa and ME at 28.2o
ASTRA 2F and 2G replacing/expanding business from ASTRA 2B steerable beam over West Africa
ASTRA 2F upgrading and enhancing African neighbourhood
ASTRA 2E bringing new steerable capacity for Middle East
ASTRA 2G expanding West Africa with new capacity for Angola & Coastal Africa
26
Expected launch date: ASTRA 2F Q4 2012, ASTRA 2E Q2 2013, ASTRA 2G Q1 2014
Payload*: ASTRA 2F Ku-Band: 12x 36 MHz transponders, ASTRA 2E Ku-Band: 12x 36 MHz transponders, ASTRA 2G 10 x 36 MHz
The Ku-band and Ka-band spectrum is shared across ASTRA 2E, ASTRA 2F and ASTRA 2G.
