Astra 2F: Scandinavia & Baltics Discussion
SteveWhit
1.8m standard dish, twin LNB. SKY HD
Helsinki, Finland
Indeed. The VPN / sky go option seems to be a 'perfect' solution.
Lose the record function. But ten again my box was full of stuff I never got round to watching.
it can be like 1n data channel
Ask
Prime focus 120cm al. dish, V2-box/actuator and quad Invacom LNB.(28,2E--15 satellites--40,5W). IPbox 9000HD.
Norway
That's a shame. Reckon there is no chance if me getting permission for a 4m dish. Certainly not from the neighbors.
However a work around is sky go. Downside is losing the ability to record everything.
Hello!
Why not find a solution together with your neighbours. Place the 4m dish on the "right spot" if possible, and from there use Invacom Fibre MDU Optical LNB or other's optical LNB's.
Regards
ASK
SteveWhit
Helsinki, Finland
Majority of people I speak to have no idea what sky is. Don't understand why canal plus isn't suitable. Plus there is the forest 15m from the back of my house. So view to the sky could be blocked.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Triax 72x79cm, Triax 003 lnb
Tallinn Estonia
Ask
Norway
The Invacom fibre optical LNB give you and your neighbours many possible solutions ---!
Retired Mod
www.timo.me.uk
Yes, Sky UK is not exactly high on the lists of priorities for the average Finn these days. I would say the vast majority are happy with cable and if they can't get cable then Canal Digital or Viasat is more than enough for most. Even on terrestrial there's plenty of films, sport and more even in HD.
Yup - the dish can be located kilometers away from the residences!
Tallinn Estonia
Assume Im a technophobe - what do those figures mean for your reception? Tallinn should have zero 2F reception on that sized dish
SteveWhit
Helsinki, Finland
Ask said:
Hello!
Regards
ASK
that seems to sound like it involves in big investment. and again it assumes the neighbours (7 houses) are all keen to recieve channels they may not understand or need.
So again, SKY Go sems to suit for now.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Yes,we need 2,4m- 3,5m for picture!
but next I will try, in same place, 110cm Triax and later 3m dish in same place.
Thank you - please let us know how you get on with the bigger dishes.
You might stand a chance with the 3m - theres a partially successful report north east of you with a 3m
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
30 km from Tallinn. No picture from Astra 2F.
Lat 59.40 Lon 24.68
Antenna 2.4M diametre, Inverto LNB.
Using same setup was OK picture from Astra 2D vertical, no horizontal beam.
You can read more in Estonian, maybe google can translate.
_www.digi-tv.ee/viewtopic.php?f=28&t=14974&start=105
The google translation from Estonian really isnt very good :-rofl2
Coverage limit on coverage seems to be falling on a very steep, so already a bit out of the need to fear a large frying pan.
That's parabolics.
skomedal
This and that
thule
Not a very warm welcome reply to a first poster, but at least that member made an effort!!!!!!!!!!!!!!
I know the site is satellites.co uk but when you request reception info from other regions ( you get what your given ) accept language problems and resist mocking them :-shh
Retired Mod
www.timo.me.uk
I think the joke was aimed at Google's attempt at translation, not the poster.
The mocking is of the Google Translation tool ........................
Edit: Snap.
skomedal
This and that
thule
But does the POSTER realise this???????????
That being my point ( language barrier )
I apologise if my previous post came over as making fun the poster - it certainly wasnt meant that way - as the others have said I was amused by the atrocious attempt google translation has made of the Estonian - English. There are numerous other oddities like that which is a bit odd because most of the time it makes a reasonably good attempt of translating from one language top another.
