Are you suggesting this wont actually move the motor?
thats what im saying yes
Ok, i will go through setting your box up step by step...no problem.
with your Gemini image in place, goto a website and download a list of channels from _http://www.dreamboxworld.com/dbw/main.htm
Look for the download...
Settings DBW E90° -> W45° Rotor All Packets
download this and use Dreambox edit to first load then send the channels to your Dreambox over the LAN
im hoping you have a shared internet connection that your Dreambox can use... to make it easier to get the latest Cam and keys.
Boot Dreambox, and choose a cam/key combo.. ie NewcamD cam and latest keys
if they arnt there your going to have to download them via the addon feature.
now on your Dreambox you will have a list of channels.
in motor setup try setting up your GotoXX info.. ie long and lat etc.
if you dont know your long/lat use this site to find it
_http://www.streetmap.co.uk/
if your really lucky, now by choosing a channel, your dish will automatically lock on (more likely that your going to be unlucky though)
if not, your going to have to find one manually and lock on, then try the GotoXX thing again.
so from a clear screen (ie not in a menu) choose RealityTV 28.2e
and lets presume the dish doesnt move...
(tip: i think your dish will already be parked at 28.2 as you said you can pick up BskyB channels when you scan, so you may already be looking at RealityTV without doing anything)
if not, do the following.
press menu and go into your motor settings press blue and goto the step dish west and east screen
change the choice of satellite to Astra 28.2 and move dish till RealityTV pops up in the background
if your not sure what way to move the dish, pop outside and compare your dish to any nearby Sky dishes, and see how your dish is in relation to them, as you look at it, (facing the wall) moving right is east.
once you have a lock, and have got the best signal you can save it!! and try the gotoXX
if you do get a picture, but your cant move to any other satellite then you will have to repeat the process for each sat...
ie choose TPS Foot on 13e and goto motor setting move dish till picture pops up or you get a good signal lock etc etc
the first time you do this it takes a while.... but it does get easier and quicker.
try that and let me know how you get on, asking any questions along the way
lets get this baby up and running.
