johnsattuk said:Picked up an Inverto C120 yesterday to try after seeing Likvids results.
It seems better than my Invacom or MTI that I have been using, it's staying on my dish, for the moment anyway.
I really like the size and weight, about 10% of the invacom, cheap as well £19.95
Rabbit said:This Inverto C120, I have also been searching and found this... http://www.wizardsatellite.co.uk/new_product-inverto__4_c120_universal~pd10409--0.html Is this the same one you guys are talking about? If its so good, I could be tempted myself.
Likvid said:You can buy from me, i have new stock arrived of this Inverto C120 LNB in Sweden.
Price is 25,90 euro + postage which is a bit cheaper than Wizardsatellite.
PM me if you want to buy.
Likvid said:And here is my test performed today with my new handpicked Inverto C120 LNB.
Look at the results and be amazed.
This is in Stockholm with a Fibo 90cm dish performing like a good offset 110cm connected to a Pace DS430N receiver, the weather isn't that good either with heavy fog.
As indicated earlier in this thread i already received 10.847 V with the SMW setup, the Inverto LNB is really the best LNB i have ever tried, it gave amazing results as you can see.
Astra 2D 10.729 V Sky Travel
QUOTE]
I dont know if you have already mentioned it,but have you compared the inverto with the invacom quad?
Rabbit said:(Maybe this should be on a new thread)
Ok...I have tried and tested the Inverto C120 IDLP-SFLANGE LNB, and these are my results...
Weather all week has been cold, cloudy and generally fine. No rain or snow and little wind. 6pm till about 11pm Horizontal Channels (BBC, ITV) suffer from pixilation and the program your watching is un-watchable. I let it run for 5 days with generally the same result every night.
Last night whilst pixilation was present, I switched back to my MTI LNB, with instant results. All the pixils are gone and all Horizontal Channels working as before. So unfortunately, this Inverto didnt work for me. Thanks Likvid for getting me the Inverto and trying it out.
I might give the Invacom a go soon, and see if I get any improvement during bad weather.
It might be different in other locations. They are cheap in cost and worth the try.iggy said:Damn, i've just ordered one, hopefully it will turn out to be better in my location
Rabbit said:It might be different in other locations. They are cheap in cost and worth the try.
