Cascading Diseq Switches
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
yeshu26 said:
You are right robbo, but the products on the ebay does not specify if they can be used for sky zone 2 dishes or not.
That is why I wanted good knowledge from the forum before I climb up the ladder.
The point is, there arent any multi lnb brackets for sky dishes, something always has to be cobbled together in some fashion.
A bit of wood and some gaffa tape, should be enough to try it out, given that you are not down south.
Also, better if you could get the dish down to have a play, rater than fiddling with it up a ladder.
yeshu26
Amiko Alien HD box
Self assembled pc:
AMD 3.2 GHZ dual core 64 bit
Gigabyte motherboard
4 GB DDR2
RAID 1 MIRROR 500 GB
Slave Drive: 500 GB IDE
Samsung optical drive
Benq HD 24 inch monitor
Aberdeen
Ok lads,
found this:
eBay Item # 300693322689
Is this is a uncommitted switch?
[warning]eBay Link fixed and formatted in Forum style[/warning]
Robbo
Retired Mod
Gravesend,Kent,UK
Pretty sure thats the product that one of our other members bought, and it's diseqc 1.1 , so fine I believe.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Anyway,
How different are the specifications of unswitched diseqec switch from the new diseqc switches?
You never know, Chinese can make mistakes in names. :)
Robbo
Retired Mod
Gravesend,Kent,UK
yeshu26 said:
Anyway,
Are you sure it's the Chinese?
What you have just written makes no sense. No such thing as unswitched diseqc switches? Or new ones?
:p
What do you mean?
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
I mean Diseqc 1.2, or 2.0 are newer than 1.1.
What I mean to ask, how different is 1.1 in specs from the newer ones?
sonnetpete
wordpress.com
Normandy, France
Don't think of them as you would software, the versions allow for greater functionality, either in switching or motor control. Read through this :
_http://en.wikipedia.org/wiki/DiSEqC
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Ok sounds good to me.
How will I configure my proposed set up in the receiver?
At the moment it is simple, as I have 28, and 5E sats. So port A is 28 and B is 5E.
Robbo
Retired Mod
Gravesend,Kent,UK
Assuming that you connect as follows
5e--> port 2 of diseqc 1.1 switch
28e --> port 1 of diseqc1.0 switch
13e --> port 2 of diseqc 1.0 switch
o/p of diseqc1.0 switch--> port 1 of diseqc 1.1 switch.
Settings in receiver
5e, diseqc 1.1 port 2, diseqc 1.0 Off,
28e, diseqc 1.1 port 1, diseqc 1.0 port 1
13e, diseqc1.1 port 1, diseqc 1.0 port 2
Using letters A=1, B=2 etc
BTW, it is possible to cascade committed switches. If you have a 2 port switch port 1 connects for positions 1 & 3, and port 2 for positions 2 & 4. So if you had a 2 port switch in the house and a 4 port at each dish you could address ports 1 and 3 of the switch at dish one and ports 2 and 4 at the switch of dish two. It really depends on the receiver. For example a Dreambox can send DiSEqC repeats so would have no problem working in that configuration and some other receivers send repeats by default.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Ta,
But I have 2.0 switch as committed, and soon will order 1.1 switch as uncommitted switches. Will they work? As your example shows different types.
Robbo
Retired Mod
Gravesend,Kent,UK
Good info huevos, must try that.
Did you read the info on Wikipedia yeshu? Some elements need clarification, but it does explain the difference between diseqc 1.x and 2.x, and that 2.x devices should be compatible with 1.x devices.
So yes, it should work, as diseqc 2.0 is essentially the same as diseqc 1.0 but with the addition of bi-directionality. Proof will be in the pudding of course, it has a chance of not working also, if the receiver sends the commands in the wrong order. Though I have tried it on a few different makes, and it has been ok.
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
sonnetpe, I lie your profile description about various redundant things. I am keen to have some of it (for money, if you like)
Does our website have a flea market section too? Or it is forbidden to trade second hand stuff here?
[/I]
sonnetpete
wordpress.com
Normandy, France
Does our website have a flea market section too? Or it is forbidden to trade second hand stuff here?[/I]
While it's true I list 'redundant' equipment I like to keep it in reserve. You can't tell when a receiver might decide to fail and once in a while I lend out a receiver to a friend (I did earlier this week actually). So, I haven't really any intention to sell off any equipment (I have just two old $ky dishes spare ATM) and in any case carrier costs from here would I think be too high (you do realise I live in France?).
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Sounds good. But I am not so well versed with satellites, so can someone please explain this in simple language, perhaps with a diagram please.
JanHJ
T90
VU+ Solo2
Gothenburg Sweden
I am using this switch (uncommited): EMP-Centauri S 8/1PCP-W2
[nolink]Admin[/nolink]
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Taking forward from Huevos idea.
Will I need identical switches to do this job? I mean the 2 port switches, do they have to be from the same manufacturer? same firmware, (does it apply to diseqc switches?).
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
Huevos, I see a little problem for my needs here.
My two dishes are very far from each other. So How would just one "four port switch" address to the mentioned problem?
Robbo
Retired Mod
Gravesend,Kent,UK
You need to actually read what huevos has written. Try drawing out what he has said.
Posted with Tapatalk
yeshu26
Amiko Alien HD box
Self assembled pc:
4 GB DDR2
Aberdeen
The problem became little more complex now.
We are getting second receiver in other room. So what kind of disqec I will need to feed two receivers at the same time?
