Hello Rolf,good evening!
okay,good idea,when time,is right,and help is here,for installing,and winter is over,i will makes a lot of pictures,at moment i finalize the setup of my mesh antenna,but is very dificult on the high roof..
need 3 meter leader,to reach the lnb
polarmount looks very rusty,so i mast try to restore it,with antirusty spray,and special protection color,what would be the best to to restaurate it?
maybe,the 36" motors does not work,i have to other one,one is from uk company strong,maybe the left the market now,and the other from drake usa
then i need a digger!
how,deep should i make the hole?
then i need a lot of this
http://dict.leo.org/ende?lp=ende&la...ctHdr=on&spellToler=on&search=beton&relink=on
dont know english word for,so i always must look into the dictonary,for special words,that i dont know in english,this site knows every word ,but sometiems i have 20 difrent words in englich,and only one word means in german,how it comes this?
a special lnb holder for kuband is includes flange,where i can ajust the lnb in the depness,to optimizing the signal flange version!
channel master told me all parts are out of stock,nothing avalible
intrsting would be now,was there,in the product line in the past of channel master also a cband tripod avalible,the f/d of the 3m antenna,i think is 31-32,i have send,my seavey feed,to an expert,that cam modify my seavey,for nearly every antenna type,so i hope ,with this,and integrated,servo polarizer,i have the best solution for c and kuband,with out lost in the kuband!
but,it needs alot,of time ,and patience!
first i can try only in kuband,maybe cband also works with the kuband lnb holder i dont know,here is no store,that can help me with big antennas,i mast find out,everything alone..!
