cos32
Well I received a reply from Humax as I went to the source
and you can read for your selfs what the reply was.
Thank You for tour email.
When you go through the initial setup with the Foxsat, it checks your post code against a database broadcast by freesat, to give you the correct UK regional variations. If the post code is shown as invalid the unit is not receiving the database, this may be due a problem with the LNB or dish alignment. You can search for the freesat home transponder manually on 11427 or 11428 horizontal. If you are not receiving anything on this transponder, you will not be able to verify your post code. You can check the footprint of the transponder at the following link: http://www.lyngsat-maps.com/maps/eb1_fixed.html
So there you have it some people on the post were quite correct.
In Cyprus the dish is peaked for BBC and ITV and due to narrow
bandwidth some of Eurobird channals are not obtainable hence the
Humax can not lock on. So I suppose I will have to leave things as
they are, I have also found out from Humax that ITV HD is also transmitted on the same trasnponder as the post code list. )(-red
