Kaon Receiver For Dish Tv
lingaraj_h
Dish TV Receiver's Zenega CD1002s and Kaon with DiSEqC on NSS6-95"E ,Panamsat12-45"E and Insat 2E0-83"E
Karnataka,India
Tom Robert said:
I have new and updated software of Loader Version: - 2.1.6, H/w: - 01.00,S/w: - 01.05.00 for Model - KSC-100 MCO fully workable for Dish TV same as I firstly got updated software of ZENEGA than anyone.
I facing A Problem Rebooting A Recivre
TR KHAN
SERVICE
Dear Tom,
if you have any magic please put here....otherwise bhuto kay KAON ka katl ho jaega.......:-splat
lingaraj_h
Karnataka,India
Can Anybody Hack Software For DISH TV New Decoder KAON K100
We are facing a lot of Problems with KAON K100 Receiver, When I switch on My Receiver That shows massage on TV every time As Below and It's take 45 to 50 Seconds
System Installing
12688Mhz, 27500Kb.v
Searching for a new software
Rebooting please wait…
After itself automatically off, After when I switch on the receiver that shows the above Mentioned massage that takes 45 to 50 Seconds even One minute Than work perfectly, can anybody solve this problem
I think this Decoder not user-friendly and Picture quality is poor and Sound quality is not good
lokesh
No I think the picture and sound quality is ok. But the problem is with booting. when I changed the receiver software with that of kaon 511z firmware then it booted rapidly. All this hapenning due to Dishtv software modification according to there use. let's complain this to dishtv.
I have a few question
1) how can I update software by set-to-set method?
2) how can I take a backup of my receiver using my pc.
any way here r some of the information which my pc received from Kaon ksc100 receiver by dishtv using Hyper terminal.Please have a look and give comments.
AVMEM SIZE = = = = 100000
STAVMEM_Init()=OK
STAVMEM_CreatePartition()=OK
STEVT_Init()=OK
STPWM_Init()=OK
STCLKRV_Init(CLKRV0)=OK
STI2C_Init(back)=Ok
STI2C_Init(front)=Ok
DECN_Init()=OK
VTG_Init()=OK
STVID_Init(VID0)=driver changed at 3 April 2003=Ok
OSD_Initialize=(OK)
Version 2.1.6 v1
Date Apr 01 2005, Time 23:04:21
NO MICOM : [EuroLoader - Sat384] 1/2M !
[FE] Version : 02.03.00 Last Update : 2004.06.16
================> HW_Ver = 0x12C501 : 0x0D, 0x2A, 0x4A <=================
DVB TYPE = 0x1 !!!!
BOARD TYPE = 3 !!!!
CI STATUS = 1 !!!!
VIDEO INVERTED !!!!
gIS_LEDFront = 2
___C_1 Detected !!! gIS_LEDFront= 2, gHEAD.mcVideoInvert = 1
HWC_VideoInvert(1)
[0], CH_ADDR[0xc0182cc4], CH_IDX[15], TUN_ADDR[0xc0082c90], TUN_IDX[0]
BOOTLOADER :: TS SERIAL = 0
[REREADCLOCK] 0-0-0, 0: 0. 0
FLASH ID: 0x234a, COM ID: 0x00bf
sdVerifyMasterOrSlaveThroughPC() = 1
NO_ACKNOWLEDGE with PC.
___ V300 BOARD DETECTED !!!!
Hdl->mcChanType = [0x0c]
Hdl->mcTuneType = [0x89]
[0x00] SHARP 0614 Is detected !!!
FE_GetTunerName(0) = ZL10
FE_GetTunerName(1) = ZL10
HW OUI:0008b9 mdl=0x2802 ver=0x0100 msk=0x0000
SW OUI:0008b9 mdl=0x2802 v
*jumpCode = 0xffffffff
gFLASH_BASE = 0x7fe00000
Jump : 0x7feffffe
STAVMEM_Init()=OK
STEVT_Init()=OK
STPWM_Init()=OK
STI2C_Init(back)=Ok
STCLKRV_Open(CLKRV0)=OK
STAUD_Init(AUD0)=Ok
STDENC_Init(DENC0, InvOut 0)=OK
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
OSD_Initialize(OK)
[FE] Version : 02.03.00 Last Updat6
SetPort4 = 0::________GPIO_ReadPort4 = 0x1f
SetPort4 = 1::________GPIO_ReadPort4 = 0xff
THIS IS LOCOST NORMAL FRONT !!!
___C_1 Detected !!![0], CH_ADDR[0xc009a31c], CH_IDX[15], TUN_ADDR[0x7fe11c64], T
UN_IDX[0]
[REREADCLOCK] 2002-1-1, 0: 3.13
NO SCART..
NO SPDIF..
VERSION : 2.7.5 (2005.03.25)
MODEL : KSC-100MCO (BUYER CODE : 40)
DATE : Apr 15 2005
TIME : 17:10:31
FLASH = 0x234a
[MC] Version : 02.02.03 Last Update : 2003.10.21
[TTXOSD] Version:02.01.09, Last Update:05.03.04
[PSI] Version:3.0.0, Last Update:05.01.14
[DB] 4000CH, 8FAV, EPG_WEEK:ON, NEW_COLOCK:OFF, GUI_T:OFF, __K4_OPTION__:OFF, (1
92512,3570)
[CONAX] Version:3.1.3, Last Update:05.02.04
####### CI DETECT #######
[CI] Version : 02.02.02 Last Update : 2004.02.02
[CONAX] Initialize complete
MMI_TYPE :: MMI_K15
MMI_API_VERSION :: 5.2.0
MMI_FLASH_VERSION :: 1.0.0
MMI_E2PROM_VERSION :: 1.0.1
MMI START OK : fa0
Statusbar2 : Reading the Smartcard
Vivek
Bandit Queen
Satellite Blood
Great Lokesh,
You have done lot of work....
Vivek
Bandit Queen
Satellite Blood
Dear Lokesh,
Please try .........
Step 1
Equipment to prepared EA. Same model (ex, CI model .CI model, PVR model .PVR model…)
RS-232 Cable (Same as you used in ZENEGA)
REMOCON
HOST STB: STB from which new software, or new channels is upgraded.
SLAVE STB: STB to which new software is upgraded.
You should copy from HOST to SLAVE STB.
Step 2
Power OFF the SLAVE STB.
Step 3
Code power (Master S/W on Back Panel) OFF and then ON your HOST STB.
Press successive FP [EXIT], [EXIT], [EXIT], RCU [MUTE] key within 3 second.
(FP means front panel, RCU means remote controller.)
Then STB will reset automatically, and turned on as HOST STB mode.
Step 4
Connect your HOST STB and SLAVE STB by RS-232 Cable.
Step 5
Power on the SLAVE STB, then SET to SET Upgrade starts automatically.
(Front panel displays the status of upgrade process, like as Dn00, Up00, End…)
Step 6
If no action on front panel, then please turn OFF the SLAVE STB and ON again.
Step 7
Even several times of retries of Step 6, if there is no action,
Please retry from step 2.
Please don’t power off, when upgrade is on processing. STB could be damaged.
On upgrade mode, power key is not available.
If there is any problem on upgrading software, then contact with www.KaonMedia.com.
lokesh
I tried these but no result
further transmission between stb and pc shows the following message( please put ur lnb wires int receivers connected)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
dynamic_check : sdt 13, 13
dynamic_check : nit 11, 11
PMT
PMT Processing
Set ECM(0)
dynamic_check : sdt 15, 15
dynamic_check : nit 12, 1
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
rst_ad
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(0)
PMT
PMT Processing
Set ECM(1)
ECM(81) : 84
ECM=>CARD : 84
acc_status = 0
dynamic_check : sdt
ECM(80) : 90
ECM=>CARD : 90
acc_status = 0
PMT
PMT Processing
Set ECM(1)
ECM(80) : 99
ECM=>CARD : 99
acc_status = 0
ECM(81) : 100
ECM=>CARD : 100
acc_status = 0
ECM(80) : 110
ECM=>CARD : 110
acc_status = 0
ECM(81) : 120
ECM=>CARD : 120
acc_status = 0
PMT
PMT Processing
Set ECM(1)
ECM(80) : 156
ECM=>CARD : 156
acc_status = 0
ECM(81) : 160
ECM=>CARD : 160
acc_status = 0
ECM(80) : 170
ECM=>CARD : 170
acc_status = 0
ECM(81) : 180
ECM=>CARD : 180
acc_status = 0
ECM(80) : 220
ECM=>CARD : 220
acc_status = 0
ECM(81) : 230
ECM=>CARD : 230
acc_status = 0
ECM(80) : 240
ECM=>CARD : 240
acc_status = 0
ECM(81) : 250
ECM=>CARD : 250
acc_status = 0
lokesh
friends, I cannot continue with experimenting with my Kaon receiver unless I get a backup
software. I need it urgently. please provide some help for the software which can take backup of
all my receivers firmware and data.
thanks.
lokesh
what language is this. Can any one convert this to simple english. this site contains a
lot of help about my kaon receiver. I need it urgently.
thanks.
ابتدادرحالی که هنوزرسیوررابه برق نزده ایم آن رابه وسیله کابلrs232 به کامپیوترمتصل می سازیم ولودررااجرامی کنیم برای دریافت لودرازطریق لینک زیراقدام به دانلودلودرمی کنیم
http://www.kaonmedia.com
خب سپس آخرین پچ رانیزدرلودرفرامی خوانیم برای دریافت آخرین پچ هم ازلینک زیراستفاده می کنیم
http://www.la-cafetera.com/kaon.htm
پس ازدانلودلودروآخرین وجدیدترین پچ بایددقیقابه طریقه زیرعمل نمائیم
نکته مهم
دراین مرحله مابه فایلfirmware مواجه خواهیم شدوبایدبدانیم این فایل چسیت وازکجاآمده است اگربه خاطرداشته باشیم برخی ازکانالهای تلویزیونی ازرسیوربه خاطراینکه کاربران خودراواداربه خریدکارت نمایندازfirmware استفاده می کردندتاخریداران رسیورمجبورشوندبرای دیدن کانالهای کارتی خشاب وکارت موردنظرخودراکه قابلیت بازگشاهی رمزبه اصطلاحseca ویاnegra و.....خریداری نماینداماخوشبختانه امروزه این سیستم کددهی کاملاهک شده وازخرج مردم برای دیدن کانالهای کارتی کاسته است خب حالادیگرکاملامتوجه شدیم این فایل چرابه همراه این پچ ارائه شده است بنابراین درقسمتopenfirm فایلfirm رافرامی خوانیم ودرادامه فایل بافرمتbin راواردخواهیم کردسپس برروی گزینهopen کلیک می کنیم حالاشمادرقسمت بالای لودرمشخصات نرم افزاروسخت افزارخودرامشاهده می کنیدودرقسمت پایین نیزبااین گزینه هامواجه خواهیم شد
(upgrade mode)
File open ok
New version binary
File open ok
New version binary
یعنی هردوفایل فراخوانده شده ازسوی شماموردتاییدقرارگرفته است
بنابراین رسیوررابه برق زده وبادکمه جلوی آن کهstandby است روشن می نماییم دراین لحظه درصدپیشرفت برای آپگریت نمایان خواهدشدودراین فاصله یک چای یاقهوه بنوشیدفقط به خاطرداشته باشیدخاموش بودن رسیوردراین مرحله هیچ خیری به شمانخواهدرساندودرتمامی مدت آپگریت رسیورشمابایدحتماروشن باشد
تبریک عرض می کنم شماموفق به آپگریت رسیورخودشدید
وامادرآخرکاربایدیک سری ازکدهارانیزبه صورت دستی واردنمائیم تابتوانیم کانالهای کارتی بیشتری رامشاهده کنیم زیراسیستم کددهی نگراویژن به صورت اتوماتیک بازشده وانجام وظیفه خواهندکردتنهاایرادآنهادیربازشدن کانالهااست
چگونه کدهای دستی راواردنماییم؟
خیلی راحت ابتداکنترل رابرداشته وبررویexit فشارمی دهیم وسپس دکمه سبزرامی فشاریم ودرادامه برای ورود1 باردکمه زرد2 باردکمه آبی2 باردکمه سبز2 باردکمه قرمزوحالادرپایان1 بارمنورافشارخواهیم داداگردکمه هارادرست زده باشیدهم اکنون بایددرسیستم کددهی25 رقمی قراگرفته باشیم ودرادامه کدهای دستی راواردخواهیم کرد
نوشته شده توسطrezasabet هرگونه استفاده فقط باذکرمنبع ونام سایت مجاز می باشد
Foxtell
ONE SDS( STAR DIGITAL SERVICE) &amp; ONE DISH TV.
Nepal
Kaon is functionality of the Euroloader, if any one have Euroloader please provide in this form immediately.
gupta2005
What's problems with my lover indians.
If you have authorized receiver and have edit function in Kaon receiver then why you waste your own time and others to ask again and again for loader. whats it need so important and what's u want more and wahts' experiments you want to do with it..
See and enjoy with the available software . Is you do special work through this LOADER , do it
Mr. vivek why did u ask or beg in this forum all the time although you have good contacts in Dish TV with SOB ( Ajay arora) and others in technical department. Ask them to give Loader if you need very urgent.
and Mr. Lokesh why you give lengthy research in this forum. You could not hack Zeneja till today instead of 100 postings and now u waste time on Kaon
Do that which is special , do not write post and post as you do in Zenega
so be constructive
lokesh
Mr gupta2005 Its very simple to give advice to others. If you r so brillient then why don't u come forward with some great results. If u r satisfied with your package and payment, then please relax in your drawing room and enjoy Dishtv. Why r u here if u r happy and satisfied.
I think you r wasting your time.
thanks.....
TR KHAN
SERVICE
so be constructive
Mr. Tom Robert
This is too much.........Why you are wasting your time.
gupta2005
Khan
I am Gupta not TOm Robert ok - correct yourseldf and do not name the members of dish Team like Vivek, tom, lokesh, and othyers . these are inner pepole of Dish TV. understand TR
Khan
Now Star Dth has to be started so wait for best hopes. then we see how this dish TV goes up its sale which moto is only cheating as Foxtell said.
Please face reality and not try to run away from that. this is the fact
hellosir
querious banda
hai i'm user of cable tv here in india
have u any idia about star dth website or any other links
need for your reply
lokesh
Mr. Gupta, please don't say that I am a DISHTV man. U don't know a single word about me, u even don't know who I am and from where I am? I hope that DISHTV people has a lot of work to do then to just post in this forum.
And please don't spoil my Image or any one else image without knowing his or her details. As u have said that DISHTV is cheat. If u associate us with DISHTV then we will be cheaters in everyone' eyes. So please think before u post.
gupta2005
Mr. Lokesh
Ok, You are not a Dish Man. You say that Dish TV people are very busy. They have no time to read and write in this forum.
Actually Dish TV India has nothing to do except how to cheat their customers and tease the customers. Despite they improve their service in respect of sound quality and picture quality and channels, they waste their time in such things and
You mean to that we all are in this forum “ Allu ke Pathae hein” who waste our time in this forum . We have much free time than Dish Tv people. think before u post
Close the discussion on baseless things and if you and other have any productive thing show on the forum .
Please not dictate story of your software in detail.
Dear Lokest : Every rough and factual thing pains everyone . so Bear it please with patient.
Please keep on topic, which is discussion of using Kaon receivers with Dish TV - personal accusations will result in the thread being closed.
TR KHAN
SERVICE
Why pin drop silences?
New Coming Channel on DISH TV is “TOTAL TV”
All waste materials (Channels) put it in dish TV…:D
geeky1
who am i ? whence am i ?
eternal bliss
illusion
