Back to the main meat of the thread ..
This mornin' oi ave been mostly up a ladder....
Removed original cam from the centre shaft ..and replaced with my modded cams ..
Getting the cam screw out wasn't easy as the case seal had leaked a little and allowed it to rust ..
but eventually it gave up and let me win..
Also replacing 4 posi screws holding down the plate with double locked M5 nuts and bolts as these were ALL loose ..
Rather than just tighten them up ..as it's again an error on Motecks part not to at least fit shake proof washers ..
over time these bolts do work loose ..and are then inaccessible once the cover is on.
I've also made the West micro switch raised platform in liquid plastic ..
Not made special ..just what eas left in the bottom of a plastic cup after cam casting yesterday..
Cut to size and drilled ..
Sadly I'm still waiting for my long M2.5 bolts so can't fit this limit switch yet..
rgds
VS
