Max.dish size
Likes
Hi All
What is the max.dish size you are allowed to install on a wall?I live in Essex.
I would like to install a 1M motorised dish on the back of the house with 2 M pole.Do I have to ask the council approval before install it?It would not obstruct anyones view.I would like to do everything legal.
Quick reply would be much appriciated.
Thanks in advance.
benblueeyes
Jaffer
Likes
Samsung A300W with component output
Hotbird & Astra2
South East England
#2
Upto a metre ok. You need permission if its over a metre.
Likes
3,129
#3
Actually I think you'll find that the limit is 90cm. If you live in a conservation area, a listed building or have conditions laid down by your landlord it could be less (or even prohibited).
Strictly speaking the 90cm is measurable in any direction so, unless you've got a prime focus dish, a nominal 90cm dish is taller than 90cm - about 98cm depending on the make. To stay strictly within the law you need to have a maximum of 90cm vertically which means an 80cm in practice.
Having said all that most people can't tell the difference between 90cm and 1m from a distance.
I suppose the big question is; how well do you get on with your neighbours? Also, how visible would it be from the road?
Likes
1,287
#4
In real terms you can get away with 1m, but the rules are 90cm. If you tell anyone who asks about it that it is a 90cm, bearing in mind that they can't easily measure it, you'll probably get away with it. :)
Likes
1,287
#5
Snap PaulR. :)
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#6
You are all very bad boys.
I have a nice legal 88cm Triax.
Only because it would hit my neighbours fence on 30W if it were a 1M!
Be interested to see what it actually measures vertically...
Hang on, I'm going to put my slippers on and stagger out there now in the dark... wish me luck...
errrr.... 96cm.
I guess I'm a bad boy too.
Likes
Hi all
It is 1M channel master dish.It will be installed on the back wall,almost center of the wall.Back of my house at the far end of my back garden 70 Feet away next house gable end.So they can't see it.My house is semi & situated in a cul de sac.Further inside my garden wall tall conifers 10 of them & hardly anyone can notice it.Only next door neighbour who is bit of a funny man& he may question about it.I've old 80 cm mesh dish(analogue lnb)& rusty.
I am going to get new dish installed end of the month,hopefully.I do not want remove it if anypone repot to council.Just wanted to be sure.
Thanks to all for the answers.
benblueeyes
Likes
Hi PaulR
It is 1M channel master.As I live in a cul de sac & my house is semi. it can only be seen from the side of the house & inside the rear side garden wall I have tall conifers..Next door neighbour is a funny old boy.He may report to council,I do not know.
You think I should ask the council?
benblueeyes
Likes
1,287
#9
If you ask the council, it will cost you whatever the local planning fee is and you still may not get it, better to perhaps have a chat with your neighbour and tell him that you are removing the old eyesore and replacing with a nice new 90cm dish, he almost certainly won't be able to tell the difference.
If you go the council route, you might as well get permission for a 1.2m dish, will pull in that little bit extra.
jimbo
Likes
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
#10
errrr.... 96cm.
I think your neighbour's a member on here mate, didn't he tell you? :eek:
BGonaSTICK
Likes
Brighton
#11
Funnily enough, they moved last week, and the new neighbours just had Sly installed yesterday, right alongside my multi-dish arrangement.
The engineer was giving my Triax a real good eyeball, and I'm reading his mind as he thinks 'Hey by the look of it, this bstard next door is definitely having some large portions of C*nax, and I wouldn't be surprised if hes doing a bit of S2 decrypting under the stairs n'all'.
... or he might just have been thinking 'only another 72 minidishes to do before knocking-off time... must be careful not to install one properly'....
Likes
1,287
#13
Technically makes little difference if it is a permanent fixture, bolt it to a wheelbarrow and they would have a hard job enforcing it. :)
Likes
Do you think I would rather have a smaller dish not 1M on the wall?
ben
Likes
1,287
#15
Well I have an 80cm on my motor and receiver quite a lot, but there are times when a bigger dish would be an advantage.
Likes
I've part exchange my unused 1M Channel Master Dish for a 90CM Channnel Master(Satellitesuperstore)+Delivery&Collection charge.I've contacted the local planning office& they want £110.00 start with for 1M dish.Therefore I choose 1st option.Install 90CM & hope for the best.They are collecting/Delivering it on Thursday.
Thanks everyone for their advice.I would not have KNOWN the law otherwise.
Will post the results very soon & may ask more questions,CAMs etc
ben
Likes
Hi all
I am about to get my dish installed.The installer left a drum of cable, Rg6XXXX ,semi air spaced & 4 core cable for motor so I could run the cables from the loft to the receiver.
I've a drum of ct100 semi air spaced & a drum of form filled ct100.The question is which cable is the best for the installation ?
By the way Satellitesuperstore has exchange my 1M for a 90CM.It will be a legal setup.Thanks to all for the advice.
Many thanks in advance.
ben
Likes
1,287
#19
I almost exclusively use foam dialectric cable now, providing that it has the good quality copper braid and foil screen, then go with the foam. :)
radtv
Supporting Advertiser
Likes
Yah, as I found out today a 80cm is crap at receving Spice Plat at 1 degree west, I really need a 1.2.
