DSM said:
I can understand the fine sand bit but why would you apply expanding foam to the satellite dishes edge?
The motor driving the dish has a multistage simple gearbox, which conseqently generates a variety of freqencies/vibrations.
It is likely that one or more of these freqencies excite the resonent freqency of the dish, and are amplified considerably. If you hold the bare motor in your hand, or resting on the carpet or similar, they do not make much noise in themselves, the dish and the mount amplifies this noise.
The edge of the excited dish will likely have the greatest amplitude and will be most effected by any means applied to dampen it's resonance. I have used various materials on dishes, underseal, damping pads as used on cars. but have not tried foam as yet, because it had not occured to me.
The foam seems like a good idea, because it is quick, easy and cheapish, and sticks like the proverbial, I shall be trying this out in the near future. I will probably foam the whole of the back of the dish.
