New Edision OS nino Pro Grey 1x DVB-S2X + 1x DVB-C/T2 Linux Enigma 2 Combo Tuner Digital Multi-Stream Receiver H.265 HEVC HD 1080p
I don't need to post a screen grab, the returned frequency is 10.558 for Newsnet with a scan from 10.700 to 11.700 set in the blind scan that uses the LOF of 9750. I have scanned this many times so know this is correct.
Reason I am confused is because your post above said "Newsnet should read 18.558 sorry.. "
Also if the receiver is set to scan 10700-11700 how can it find a channel at 10558?
Sorry typo 10.958...
the 18.558 was a correction to my post number 162
Here is a post earlier in the thread with newsnet scanned in in Ku....
10958 - 9750 = 1208
18556 - 1208 = 17348
So looks like your local oscillator is 17350, not 17250.
Save this file as "plugin.py" without the .txt extension and send it to the receiver.
Set up your tuner as local oscillator 17350 in all 3 places. Turn off tone mode. Restart box. Do a new scan.
  • plugin.py.txt
Perhaps scopus has a Hughes LNB from the USA like I did? That has a 17350 LOF.
All done, but blindscan did not find anything unfortunately, but a manual scan works! At least newnet is now showing and working at the correct frequency1.jpg2.jpg3.jpg4.jpg5.jpg
Perhaps scopus has a Hughes LNB I got from the USA like I have? That has a 17350 LOF.
Yes thanks Llew I have, another mistake on my part:-doh:-doh:-doh
10958 - 9750 = 1208
Would a reflash of VIX cure the no tranponder issue with the your py file resent to the box?
Might try going back to the 11 vix version then sending your file again. The box is funning 12 at the mo.
stephan94
Bavaria
Hello
I'm sorry to come back with the blindscan problem in C band, but it does not work at all.
I did an online update, after I went on a C-band satellite, the blindscan it offers is with KU band frequencies.
You can see that in the specifications of the LNB on this satellite in band C everything is well indicated.
It is also impossible to change these KU frequencies into frequencies for the C band.
After trying the changes without success, the C-Band menu no longer appears
The modification made for the blindscan KA band has unfortunately create a big error for the band C.
This error can be seen when you want to make a blindscan C band again, however programs already found with the previous version are still readable.
this error was also seen and announced on other E2 receiver with blindscan with their last update (maybe the Openvix( huevos) plugin.py was used ?1onlineupdate-vert.jpg2Konfiguration Cband-vert.jpg4blindscan nac versuch-vert.jpg )
Hello
this error was also seen and announced on other E2 receiver with blindscan with their last update (maybe the Openvix( huevos) plugin.py was used ?View attachment 120671View attachment 120672View attachment 120673 )
Further to last night, reflashed the Vix 11 image did online update to move to version 12, applied Heuvos's patch and bingo, blindscan for Ka 19E is now all correct and working!
stephan94
Bavaria
Where could this problem come from ?
did you update online (or usb) or did you use the plugin.py not sent Huevos or both sets ?.
is it the same version as mine?
What did you write for the Modus tone 1onlineupdate-vert.jpg2Konfiguration Cband-vert.jpg? ON ;Off or band ?
do you resume the setting of version 11 or you start from the beginning?
What did you write for the Modus tone View attachment 120685View attachment 120686? ON ;Off or band ?
Id start afresh with version 11 via USB, then online update to 12, a complete fresh install..no channel backs ups etc..
stephan94
Bavaria
I will try with a new complete installation since the beginning
stephan94
Bavaria
No difference ,
it still does not work (blindscan C band impossible)
I have a crash log
if someone finds a solution for my problem.
I really have no idea
  • Enigma2_crash_2018-11-15_08-51-51.zip
That is because you are not using the latest version.
stephan94
Bavaria
What last version? :(
I am with version 5.2.012 Online (this morning),
I can not do anything more.
What should I do more? :confused
