Triax 1.1 motor needed
frund
triax 1.1 tm 1500ci+ dm patch. Moteck 2100. Intel 4300 based pc . LG7500. 32" lcd
Wales. UK.
Hi, I have triax 1.1 fixed dish. tm1500ci, fed up moving it manually especially when its piddling.[footy] When I read posts about motors, there always seems to be a choice of answers. Do I go triax H to H 36v V box etc. or stab type which would be cheaper.. but may not last. Are there any triax users out there. Quite windy here although patio pole mounted. thanks.
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Could use a Stab HH120, but 36 volt would be better.
You get what you pay for !!! ;)
frund
Wales. UK.
I have just been looking at pricing, 4core cable, dis to 36v, Arm jack, H to H, may be too expensive. thanks for 2nd opinion.
psats
been useing stab type motor on 1.1 steel dish for over 5 years.the motors still working had no probs.
but it is sited low on my shed to hide it from the worst of the weather
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
We go round this loop many times (...a week probably).
Actually, the answer is always the same. Most 'high end' (LOL) DiSEqC motors are rated up to 1.2m dish capable. That's the manufacturers' recommended upper limit. Go over it, and you're pushing your luck. Stay well under it and you're probably OK. The closer you get to the limit the more likely it is that the motor will suffer loading detrimental to its continued trouble-free operation. That's what it says on the box.
Sheltering it will reduce the load and therefore the risk. Stick it above the roofline in a windy area and watch it self destruct PDQ.
36V systems are generally stronger and more powerful, but more expensive.
You need to apply you're own way of thinking to the above facts.
But before you torture yourself with the decision as to which route to take, check your bank account. If all you can afford is DiSEqC then the choice is DiSEqC.
Balance the various factors (location, wind-factor, cost, required longevity/reliability) then factor in the amount of risk you're comfortable with and make your choice.
See? It's easy! :p
STICK
frund
Wales. UK.
Here is my triax 1.1 with pole and calibration helpers[white plastic marked with sat positions 1 bit on dish 1bit on pole] facing 13e on my patio weighted down with bits of concrete awaiting further attention... but upright. I think after reading your posts to go for the cheaper option. not a lot of money at the moment and I need a HD dvd recorder for footy.
Thanks all for your help
frund
Wales. UK.
one final point motec sg100a any problems anyone? price seems resonable thanks
They are a great little motor, but I will say that the two i have seen with 1.1m dishes have both developed backlash. Have adjusted the backlash on one of them, it only remains to be seen how long the adjustment lasts. :)
frund
Wales. UK.
Anything else I should look at Rolfw, I notice you have a motec sg2100 any probs ? thanks
Not with mine, it is in an exposed position, but it is only an 80cm. :)
frund
Wales. UK.
There is on other I looked at stab hh120 this has a 3 year guarantee and will take up to 120cm dish
The sg2100 is on the very short list. I not sure why I bought such a big dish but it is quite sheltered.
Sat_Elite2
Can i have your money?
Dont have none yet.
Europe
I got about same question, should i get Polar Mount or 36V motor, SuperJack SMR-99G any good?
I heard many of motors have huge amount of play and dish vibrates on wind causing losing of satellite signal.
And frund m8 its called Moteck.
BGonaSTICK
Brighton
Either of those two will do nicely, but as you say the dish is a bit big for them.
Still, if it's sheltered then give it a go. The Moteck is cheap, but the STAB is about 50% more.
frund
Wales. UK.
The stab 120 is about £60 If you've seen it cheaper give us a nod.
SatElite 2, If you do the jack arm way, you need H to H Mount, 12" Jackarm, V box to convert to 36v and 4 core cable [special screened 2+2 cable can be had from a well known superstore for satellite bits]It does work out b***dy dear the latter way.
And a big TAR to the helpes above
BGonaSTICK
Brighton
Moteck is £40 - £45
That Stab is a good price.
frund
Wales. UK.
It is £74 with postage Germany.
BGonaSTICK
Brighton
Try ebay:
here for example
or
here
or
here
or any number of German or Dutch retail outlets, including one of SatsUK advertisers here
frund
Wales. UK.
That is a hellofa good price. BGonaSTICK, I was looking at the stab 120 which is dearer but money talks £30 saving will go a long way towards my trip to Everton tomorrow v Arsenal. And to be honest reading the help above I don't think at the end of the day there's much difference
just ordered one 2 or so days delivery prob tuesday £39.9 inc del
BGonaSTICK
Brighton
Fantastic. I hope you win tomorrow :) ...and enjoy your £30 :D
STICK
frund
Wales. UK.
Arrived this morning 1015am and its dry outside. Bigger than I thought. Started putting it up light rain, set angles ooooh dish angle too high, piddling down, Fitted dish originally with pole to dish bracket upsidedown so I turned to hotbird and lowered the dish with the motor elevation adjustment untill tomorrow. Quite easy change bracket adjust elevation If its dry. And I want to go and watch Shrewsbury. How did I put the bracket wrong No instructions and nothing on line to help Triax etc.
