EuropaSat/Hellas Sat 3 & GSat 17 VA-238,
.... It's time to put the brake's on, she's nearly there
I don't always trust n2y0 for accurate real-time obvs (or Gorbtrack for that matter). The latter is behind by ~2°.
n2yo might overrun when the bird actually reaches 39°. Has done with other moves before.
Time 07/08/2017 12:09
n2yo always overruns even when the satellite has stopped as it is not working on real time just updated periodically so it is only a guide.
Llew, you have not yet updated the TLE's in GorbTrack, I see 3/8/17 who tle latest one is 6/8/17 now.
The TLE of 3/8/17 did not have HS-3 at "full speed" yet, hence the 2° difference.
Speaking of GorbTrack, I think it's still the most easy to use software for bulk-checking of the GEO belt.
Beware though of a nasty bug in the used SGP4 component DJTSatLib.dll of David Taylor, that puts several inclined satellites at the wrong longitude.
For example, EchoStar 21 appears at about 7.3°E, while it's actually at 10.25°E. Other softwares and sites may also use DJTSatLib.
Sadly, David couldn't find the problem and does not bother about it any more, while still promoting his own software WXtrack. :(
Should've checked that Hans, thanks.
Problem - forgotten how to update it manually! In Tools - Options I have Auto Update ticked, but nothing updates.
Indeed, Auto Update does not work, I leave that options unticked.
Instead, routinely click the icons at the right of the Keps Data URL's, before using the program.
That's why I had a problem before, no icons :(
Never seen that yet! And I have run GorbTrack on several PC's and Windows versions.
By going to the URL's, then "Save as" towards the "Keps" folder does the same.
I get my TLE's differently anyway, to have them all 100%, but that's a different, long story... and want to stop going offtopic here!
going to the URL's and "Save as" towards the "Keps" folder does the same.
Won't let me in to save new TLEs. Access denied. I've updated before a long time ago, but can't remember how.
I'll have a try again later.
s-band
Essex
Long ago I used STK, AGI.com to work out what was overhead. All I remember is that it worked but was a hell of a learning process and look angles required paid-for add ons. Has anyone used it recently?
@Llew should this have a new thread?
Long ago I used STK, AGI.com to work out what was overhead. All I remember was that it worked but was a hell of a learning process and look angles required paid-for add ons. Has anyone used it recently?
Yes I use STK regularly, but only for a very limited purpose: to check GEO satellite locations in the long (past) term.
For a satellite, it can combine all TLE's issued, and generate graphs of this, I post them in this board occasionally.
@Llew, that sounds like the restriction new Windows versions set on files in the Program Files (x86) folder.
Should be easy to solve, by setting Properties - Security - Permissions to Full Control, for the Gorbtrack folder & subfolders.
That didn't work for me. Trying again, I simply made a new geo text file with the latest TLE's and cut and pasted into the keps folder; needed Admin privileges though, even though I have full control for this program (?)
Anyhow, thanks guys.
Restarted the two beacons in the Ku band. It is currently slightly further west of the HS-2.
I see what you mean @william-1 , it's shown at 40.25° E at the moment by N2YO and also Jens tracking site. Can someone confirm the exact position with a real-time tracker.
Still no new Ka beacon / activity observed at present time.
Some Ka action around 18721 this morning (Athena-Fedus beacon at 37.8E to the left).
My TD88 dish scrapes the fence at 39E, so may not be truly positioned for a peaked signal.
... It always happens when iv'e been out Llew lol.
Quite a selection to look at.... but just seem to be carriers only at this stage, unless it's a modulation that my pc card or Promax will not recognize.
Assuming these are RHC sigs that i am set up to recieve the levels are ranging from 8dB to 11dB at the moment.
Too weak for me to resolve or even show as separate carriers John.
Will keep an eye on the band and hope for something more lucid.
.. in the blink of an eye they go from nearly a full span of carriers to nothing, all together.
