Advice Needed my future plans
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
It is a shame that you did not include 52 east & 45 west satellites as this will mean a return visit of the installer & you will have had a better idea of how your dish is tracking the arc.
its works though
John Pykett
Persona non grata
also why does my dish say broadband on it
Non comprende. Because someone wrote it?
It actually says
Satellite and Broadband
It's advertising for Mix Digital, who are involved with both those activities. The latter being Broadband by Satellite, of course.
John Pykett
Persona non grata
It actually says
so that dish can be used for astra broadband then
Possibly.
I suspect the advert is broader brush and refers to their entire range of dishes, not necessarily or specifically that one.
sonnetpete
wordpress.com
Normandy, France
The dish possibly yes, but you'd need a totally different LNB set up....not to mention subscribing to a sat broadband service.
John Pykett
Persona non grata
i dont really need satellite broadband, i use virgin media broadband instead
list of satellites i have tuned in:
1w
4.8e
7e
9e
13e
19.2e
23.5e
28.2e
That's quite a reasonable "start" (and should not be a "challenge" to any experienced installer with the right equipment) but only about 1/3rd of the arc that I would hope to see to confirm that the dish is aligned and tracking correctly - as previously mentioned, with an 80cm dish it should be possible to get the stronger sats to around 30W and (at least) 42E (& possibly 52E) unless blocked by hills, trees, buildings, or the like.
John Pykett
Persona non grata
i think that might be my arc cause of the surrounding objects in my area
John Pykett
Persona non grata
By that I assume you mean the noise when the dish hits "something" solid (a wall, etc.)! :-lol
So, all he has to do it to move the dish gently by a small amount to the E (say from Astra 2 at 28.2E to Eutelsat 33 at 33E) or W (say from Thor at 1W to Eutelsat 8 West B at 8W) of the existing set of sats, and then so on further to the E and to the W - and take a look at the dish after each movement to see if it is getting close to anything solid!
Then set the dish E& W movement limits in the Motor menu (as described here for example - does not seem to be in the manual, which also true for a lot of other functions/adjustments which exist but are not documented in that book :() to prevent the dish going any further along the arc in those directions.
John Pykett
Persona non grata
im fine with what i get
Fine, but I trust that you now have the info to experiment further if you ever decide that you want to try to get more sats.
John Pykett
Persona non grata
hey if analoguesat sees this he will be proud :)
John Pykett
Persona non grata
update 2: just found out im unable to get 9e
