stephan94
- Jun 30, 2008
- Age
- 66
- Bavaria
i am the only beta tester="John, post: 1025487, member: 175005"]thanks stephan that's a big help. There have been problems in the past with some Technomate receivers that had the LO "user" option in the menu to do blind scans on various Ka bands and C band lnb's that used LO's of 5.76 or lnb's that do extended C-band frequency coverage like 3600 - 4800 etc but when you pressed "Go" or whatever, the rx just failed to start or crashed . Do you know of any beta testers that can run a successful blind scan on these less common lnb and band choices.
I know this video very very well
With the band C, the blindscan also works without problem
