Newbie Here Getting started
Pmann93
None - yet! Moved into a rented flat with satellite cables. Need help with set up.
S London
1E693C3A-1FE0-446D-9DE8-D229C8073E30.jpeg Hello!
I’ve recently moved into a rented flat with no ‘traditional’ digital aerial. Instead, poking from behind the bookcase are two cables which I think are satellite cables. (Photos included)
First question - am I right? Secondly, why are there two of them? I’ve looked at some freesat boxes on Amazon - some only have one Satellite input. Do I need to find a box that has two inputs? If so, are these much more costly? Most basic box I could find (no HDD) was ~£99.
Help and advice for this novice greatly appreciated!
Hi there - welcome to the forum.
Those certain;ly look like a satellite feed from a dish or a distribution system in the premises. Two cables allows thew use of two tuners on a receiver - which means you can use the pvr function of Freesat+ or SkyHD+ receivers.
Should you buy a single tuner receiver just connect one cable to the back - it doesnt matter which one.
There is an outside chance it could be a Virgin Media feed if the area is cabled - check with the building maintenance people. Chances are though its a normal satellite connection.
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
View attachment 110524 Hello!
just plug the cables into a twin tuner freesat box and see if it tunes in, if it does then the cables are for satellite but however if it does not tune in, its either that a dish is pointed at a different satellite or the cables are for virgin media.
Archive7
If you can get hold of a cheap satellite meter, just connect each cable in turn and see if you get a beep.
Pmann93
S London
Thanks all - very helpful indeed.
It appears these cables are Virgin Media cables - which is particularly frustrating since I opted to go for a Sky Broadband package after being messed around by VM for weeks on installation delays!
I may give the satellite meter thing a go, however.
One follow up question - is there such a thing as a 'generic' cable box that I could use to plug the cables into and receive the free to air channels - or would I need a Virgin subscription?
John Pykett
Persona non grata
well there are cable boxes but i wouldn't advise plugging it into the cables cause virgin media can detect non virgin equipment on their network
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Do you know that from your own experience John?
satelliteman
What about installing a dish and running a cable?
They don't look like Virgin cables, appearing to have copper cores, and they are certainly not the type of "F" connectors they use.
See if you can borrow a sky box from a friend, if that works and if you don't need to record, then there are hundreds available on ebay due to the Sky Q roll out and for very little money.
John Pykett
Persona non grata
@Pmann93
Can you see any sort of dish on the walls or roof of the building? If so, any chance of a photo?
