USB KVM Switch.
Archive-8
it seems I could do with a kvm switch.
I don’t need them for the picture, as the FreeNAS is all done via web interface or command line.
It’s my tvheadend/mint Pc and my regular Pc I want to share the mouse and keyboard with.
It’s becoming a pain to keep pulling the machines out to plug in a keyboard and mouse.
Are there any to avoid or can someone recommend a good one? (Or are they all about the same)
Thanks.
Terryl
Custom built PC
I use the ones from Belkin, never had a bit of trouble with them.
Can TV Headend machine not accept SSH connections?
archive10
Ordered a cheap one on amazon in the end.
I'm sure you'll be fine with that. I have previously used Belkins (VGA) like Terryl, but currently mostly using ATENs (for all DVI/HDMI operation). If you don't require video support, they are all more or less the same. Main difference I seem to remember is the keyboard sequence to switch between connected computers...
Archive-8
Yes both machines have their own screens, I just needed it for the mouse/keyboard input.
