Novel Idea.....
Link didn't work for me
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Replace XXX by www
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Well, the fact that the 'elevation' motor has a bend of 30 degrees in its axis in this case doesn't make this setup really easy....
Replace XXX by www
Got it. I've seem pics of something like that when I looked for images of Dark Motors. Very interesting.
You could fit a second elevation motor in parallel to cancel out the offset.
And then it would seem to get "even more complicated" - apart from the extra loads and mis-setting issues with all the various mechanical interfaces.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
You could just unbolt the 30 degree offset mount and bolt on a straight one, most motors (Apart from the HH100/120) you can remove it.
aceb
Prof Tuner 7301 /
Sussex
That won't wobble too much in the wind :-rofl2
Trust
Nijmegen Netherlands
I doubt the elevation motor can lift the setup wenn a Triax 110 dish is in front .
Also the amps of that motor will raise too high for the used receiver .
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Current should be fine if you use one motor at a time, but can see what you are saying about the load on the motor lifting it straight up, it's not geared to do so.
anto@
italy
when I used the diseqc engine I did it this way simple safe and reliable
anto@
italy
to go up and down the engine I used a 2-channel card for electric gates and a remote control with 2 keys up and down
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
That looks amazing, what a great idea :)
anto@
italy
this instead done to a friend the movement is manual
Terryl
Custom built PC
Yaesu has a satellite rotor, it can do 360 degrees AZ by 90 degrees EL, with the optional computer interface and software you can track a moving satellite (like a HAM Oscar) very effectively.
It does cost a bit but it works, with a proper counterpoise you could swing a very large satellite dish.
https://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=104&encProdID=79A89CEC477AA3B819EE02831F3FD5B8
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Nice solution, Hope it's better than their radios, personally having spent £3000 on Yaesu stuff, I'd never buy anything from them again.
Sold the lot in the end :)
My Ft-101E cost me about £140 all in, came with the 12v inverter as well, which is nice.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
That's a proper Yaesu though, when they were originally Yaesu Musen.
Does yours still have the protective film on the front?
Cripes. My first HF rig was a Yaesu FL50B and FR50B combo.
