TJExcalibur
- Master Focus 90cm .Gigablue UHD Quad 4K on TM 2600 motor. *Tm 5402 HD M3, *Atemio Nemesis. *Not Used.
- Southern England
Got it. I've seem pics of something like that when I looked for images of Dark Motors. Very interesting.Replace XXX by www
Well, the fact that the 'elevation' motor has a bend of 30 degrees in its axis in this case doesn't make this setup really easy....
And then it would seem to get "even more complicated" - apart from the extra loads and mis-setting issues with all the various mechanical interfaces.You could fit a second elevation motor in parallel to cancel out the offset.
Current should be fine if you use one motor at a time, but can see what you are saying about the load on the motor lifting it straight up, it's not geared to do so.I doubt the elevation motor can lift the setup wenn a Triax 110 dish is in front .
Also the amps of that motor will raise too high for the used receiver .
That looks amazing, what a great ideawhen I used the diseqc engine I did it this way simple safe and reliable
https://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=104&encProdID=79A89CEC477AA3B819EE02831F3FD5B8
Nice solution, Hope it's better than their radios, personally having spent £3000 on Yaesu stuff, I'd never buy anything from them again.Yaesu has a satellite rotor, it can do 360 degrees AZ by 90 degrees EL, with the optional computer interface and software you can track a moving satellite (like a HAM Oscar) very effectively.
It does cost a bit but it works, with a proper counterpoise you could swing a very large satellite dish.
Code:https://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=104&encProdID=79A89CEC477AA3B819EE02831F3FD5B8
My Ft-101E cost me about £140 all in, came with the 12v inverter as well, which is nice.Nice solution, Hope it's better than their radios, personally having spent £3000 on Yaesu stuff, I'd never buy anything from them again.
Sold the lot in the end![]()
That's a proper Yaesu though, when they were originally Yaesu Musen.My Ft-101E cost me about £140 all in, came with the 12v inverter as well, which is nice.
