New Gibertini 1.5 Dish
RimaNTSS
Some SAT-related hardware.
N-E from Riga
It looks quite fresh! Good job!
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Ghostleader
Glasgow,ish!
Lovely dish. I always felt lacking with a 1.5m - it almost felt like a compromise/stop-gap for the 1.8m. But it's an excellent performer and multi LNB friendly unlike most 1.8m..
RimaNTSS
N-E from Riga
Agree with you CJ. But, in fact, it is possible to make any offset dish, including 1.8m one, multifeed-friendly.
saj1985
Dreambox 800HD SE, Dreambox 500S, Skybox F5S, 90cm Solid Dish, Tm2600 Motor, Inverto Black Ultra LNB! :)
Lost...
looking good mate :Y
gap30
technomate 90cm dish
Liverpool
Whilst I am a big fan of the look of the CM's I also have the occasional admiring glance at my 1.5m Gabriel she is a thing of beauty (and her little sister)
Surely Gabrielle ?
gap30
Liverpool
Only on a Thursday :)
RimaNTSS
N-E from Riga
Need to get a permanent base sorted.
What’s the best options?
Is it on a tripod mount, if so you could use 3 concrete kerb stones from a builders merchant, approximately £10 to £20 each depending on size. Travis Perkins sell them if you have a branch local to you, as should most other builders merchants.
BS Concrete Bull Nosed Kerb 125mm x 150mm x 915mm | Travis Perkins
BS Concrete Half Battered Kerb 125mm x 255mm to 125mm x 175mm | Travis Perkins
Drill the kerb stones with a masonry bit and use rawl type bolts to secure the tripod base down. Screwfix sell rawl type bolts that are a decent price and cheaper than the genuine branded rawl versions.
RustySpoons
Sleepy Hollow
50E - 30W
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Im using similar on my CM 1.2 install, I have some concrete slabs like that with rebar in. I will drill holes and fit some M12 throughbolts that I have here.
Trust
Nijmegen Netherlands
Archive-8
Finally got the new runs of coax I wanted, one is for the 1.5 dish, 1 run is for the lnb Changer, 1 run is for my radio scanner/sdr also added some 4 core cable for the motor.
Plus I managed to pop the conduit cover back on in the lounge. (You would never know it’s been off)
While I was in the loft I found the rf distribution amp and found it is not dab compatible so I have ordered a replacement that will allow dab.
Now I just need to pop that aerial up :D
It’s slowly starting to progress forwards.
