Hi, i have retired the Moteck SG2100A after 14 years! It was still working when i decided to see, if i could use usuals on a enigma2 receiver. So i did a factory reset on my Amiko SHD-8360 which i had setup diseqc 1.2, and connected it to my Edision OS Mini 4k. I didn't get usuals working straight off but got it to move using diseqc 1.2, after saving 2 satellites and trying for a third one it moved to an unknown satellite, maybe zero? Anyway after a couple of tries going from diseqc 1.2 and usuals it moved all the way east pass the 80 limit and stopped, i went up to the rooftop and managed to get it back manually to zero after 3 hours of plugging and unplugging the cable, and using the buttons on the motor to get it to move. So i did a reset on the motor and that was it, stuck at zero. So i dismantled the motor and took it down to the receiver, but still no movement, anyway i tried to unscrew the bolt on the axle to open it up, but to much rust on it, so will do that at a later time with some help from a mechanic perhaps
I set up the Gibertini OP100L again as a fixed antenna on 13 east and decide to upgrade the plastic lnb holder to a MFK1-49 from the manufacturer, i found one at this link
https://www.satfreax.de/antennen/adapter--multifeed/gibertini-mfk-1-49-premium-druckgusshalter-upgrade-kit
I'm posting some pictures from the installed product before and after, and also i have orded a new Moteck SG2100A from Greece.
