- Mar 29, 2004
- UK
The presidents' cup golf appears to be on 7E, and the signal strength seems to indicate I should pick it up fairly easily...
Please note that the LNBF you have is for C-Band and the Presidents Cup golf feed you refer to as being on 7.0 East will be in Ku-Band, there are no C-Band signals from 7.0 East.
If you wish to receive 7.0 East with your 3.0m mesh dish you will need to use a Ku-Band LNB. You could of course install a separate dish for Ku-Band that you indicated might be an option earlier in this topic?
