Express 80 (will be 80E) & Express 103 (will be 103E)
Express 80 & 103 are currently due to launch on a Proton in April. Both will be serving Russia from the 80E & 103E orbital slots.
more delay to july or august 2020
Proton-M/Briz-M | Ekspress-80 & Ekspress-103
International Launch Services | USA
Baikonur Cosmodrome, Republic of Kazakhstan
July 31, 2020, 3 a.m.
Khrunichev State Research and Production Space Center | RUS
July 29, 2020, 9:27 p.m.
tempo
47.5N, 42.2E / Russia
The launch has been postponed for 24 hours due to the additional testing of the Breeze-M booster block.
By the updated info, Express-103 will work at 96.5e position. 103e is its reserve position. Probably this sat will be relocated to 103e later, after Express-AMU3 launch to 96.5e position, or it was decided to swap the positions of these satellites, it isn't clear at the moment.
Both satellites will use electro-propolsion engine to reach the geostationary orbit.
Express 80 will travel to the GSO within 152 days, while Express 103 will travel to the GSO within 160 days:
The in-orbit testing of both satellites is schedulled to January-February of 2021.
I can't find specific footprints outside of these content in documents.
  • EXPRESS-80 SATELLITE SPECIFICATIONS.pdf
  • EXPRESS-103 SATELLITE SPECIFICATIONS.pdf
tempo
Both Express-80 and Express-103 satellites have separated from the Breeze-M booster block successfully:
For some days I have been detecting telemetry signals, from objects 2020-053A (should be Express-80) frequency 3405,72 RHCP and 2020-053B (should be Express-103) frequency 3404,78 RHCP.
Progress during the last 3 months.
If the trend continues like this, Express-80 could be stationary in 1 or 2 weeks, Express-103 a few weeks later.
Not yet.
tempo
The testing of Express-80 sat in Ku-band has started this morning at 80,5e position.
Test carrier 11606 V in wide mode was active an hour ago.
Test carrier 11672 H in wide mode was active just a moment ago.
Sorry, can't attach my screenshots atm, will do later.
tempo
The test carrier 11672 V is active atm, in wide mode
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Great!
Stength?
tempo
The test carrier 11483 H is active atm in wide mode.
tempo
Pierangelo
Italy
150 cm in northern Italy, I Will check the regular trasmissions.
Pierangelo
Italy
Where are you?
