Listen Up Octagon SX88+
I think it means enter the backup & recovery menu and then press 4761.
http://www.octagon-germany.eu/
Firmware (Software) Update V10558 07-07-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. OSD Sprachauswahl Menü im Start Assistent verbessert.
2. Funktion Backup - Wiederherstellung verbessert.
3. Device ID und SN Funktionen für Stalker Portal eingebaut.
1. Start assistent Wizard Menu improved.
2. Backup & Recovery function improved.
3. Added Device ID and SN option for Stalker.
E2TV Nutzung auf OCTAGON SX Modellen:
a.) Installieren Sie die aktuelle Firmware v10558.
b.) Starten Sie das Plugin E2TV.
c.) IP Adresse Ihres Enigma2 Receivers eingeben und speichern (verbinden).
E2TV use on OCTAGON SX models:
a.) Install the latest firmware v10558.
b.) Start the E2TV plugin.
c.) Enter the IP address of your Enigma2 receiver and save (connect).
OCTAGON SX modellerinde E2TV kullanımı:
a.) En son yazılımı v10558'i yükleyin.
b.) E2TV eklentisini başlatın.
c.) Enigma2 alıcınızın IP adresini girin ve kaydedin (bağlayın).
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ SE C/T2 & SE C/T2 WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online Update verfügbar!
Online Update ready!
Online güncelleyin!
OCTAGON GERMANY SUPPORT
Manikm909
Small'ish Dish Man
Kent, UK
Any chance of a decibel reading octagon...
SimonE
Gloucestershire, UK
I use an SX88+ and ever since version 1.05.52 where 27.5W was added I haven't been able to scan 11346H at 10E AFP. So I have decided to stay on 1.05.50 which works fine.
Same sort of problem here with the 27.5W on the SX88+_Optima went back to 1.05.50 as NHL did not work on 22 west with the latest patch.
tallkeith
Octagon SX88+ 80cm dish Technomate motor
Hertfordshire UK
I cannot receive any of the French multistream channels on Eutelsat 5W
They used to work but looked today and nothing
I rescanned 12732 V 29500 but nothing. Is there something I have missed?
(RAI multistream is fine)
I'm located 30km north of London 1.1m dish
Thank you
Working fine here on the SX88's neglected cousin, the Edision Primo. Are you sure it's not the weather, 12732V is a harder catch that the Italians.
No problems here with my 88cm Raven Mesh Dish on 5°west multi-streams with SX88+ very little signal loss during a downpour :)
Stevenvc19
3x Edision Primo S2:
30W
5W
0.8W
4.3E
9E
13E
19.2E
28.2E
Willebroek Belgium
Thank you
Have you tried changing the symbolrate to 29000? Or are you sure the symbolrate in your receiver is 29500? I’ve seen some complaints and eventually the symbolrate was wrong. Can’t recall wether it was 29000 or 29500 that did the trick…
tallkeith
Hertfordshire UK
Many thanks all!
The answer is ------ dish needs alignment!
The signals are a bit weaker and rain wipes them out and pixelated when its clear - so I need to fiddle with the dish.
Its on the roof - so wait for nice weather.
Firmware (Software) Update V10569 14-11-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. Xtream M3u und Stalker verbessert.
2. DVB-S2 Tuner CH. Zap Geschwindigkeit verbessert.
3. Internet CH. Zap Geschwindigkeit verbessert.
4. Picons aktualisiert wie Astra19 Hotbird13 Türksat42.
1. Xtream M3u and Stalker improved.
2. DVB-S2 Tuner CH. Zap speed improved.
3. Internet CH. Zap speed improved.
4. Picons upgrade like Astra19 Hotbird13 Türksat42.
1. Xtream M3u ve Stalker uygulamalari iyilestirildi.
2. DVB-S2 Tuner Kanal gecis hizi artirildi.
3. Internet IPTV Kanal gecis hizi artirildi.
4. Astra19 Hotbird13 ve Türksat42 Picon`lar güncellendi.
a.) Installieren Sie die aktuelle Firmware v10569.
a.) Install the latest firmware v10569.
a.) En son yazılımı v10569'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
Firmware (Software) Update V10572 19-12-2021
OCTAGON:
SX88
SX88+ Plus
SX88+ SE & SE WL
SX88+ SE C/T2 - WL
SX888 IP & IP WL
ASAT HDR No.1
SX88+ Optima
SX88+ Combo
IP
IP WL
S2+IP
S2-IP WL
Changes:
1. OCTAGON SF8008 Fernbedienungscode eingebaut.
2. Sendersuchlauf für 4.8E und 1W Thor verbessert.
3. TimeShift für Stalker verbessert.
4. UserAgent fix.
5. HDMI Ausgang fix.
6. Video Treiber aktualisiert.
1. OCTAGON SF8008 Remote Control (RCU) added.
2. Channel Scan for 4.8E and 1W Thor improved.
3. TimeShift archive for Stalker improved.
4. UserAgent fix.
5. HDMI out fix.
6. Video driver upgrade.
1. OCTAGON SF8008 uzaktan Kumanda destegi eklendi.
2. 4.8E ve 1W Thor uydulari kanal arama özelligi iyilestirildi.
3. Stalker TimeShift arsiv özelligi iyilestirildi.
4. UserAgent özelligi iyilestirildi.
5. HDMI cikis hatasi giderildi.
6. Video sürüm güncellendi.
a.) Installieren Sie die aktuelle Firmware v10xxx.
a.) Install the latest firmware v10xxx.
a.) En son yazılımı v10xxx'i yükleyin.
SX88:
SX88+ Plus:
SX88+ SE & SE WL:
SX88+ Plus OPTIMA:
SX88+ Plus COMBO:
SX888 IP & IP WL:
ASAT HDR No.1:
IP & IP WL:
S2+IP & S2+IP WL:
Online güncelleyin!
tallkeith
Hertfordshire UK
No answer from Octagon - I suppose I have to return the SX88+ as I cant watch HD channels on it. Shame as its good on SD
I gave up on the SX88+ due to sync issues too
Been using the SX88+, and the earlier SX88, for several years, but I never noticed that issue to any extent.
Therefore please describe your setup, - notably the models of the connected TV(s) &/or AV receiver(s) you were using with it as the sound sync settings on those might have been the source of the problems.
fcmelga
Hispasat,box octagon sx optima combo
Portugal
Good afternoon, openvpn is not working. we put the user and the pass, we press the red button to connect, and is always off. I entered the box by ftp and there is no openvpn installed. in the "local" folder there is only the file with the user and pass, there is nothing else to talk about vpn. Is there something I'm missing?
Afternoon All
Just beginning to delve into the GT Media Combo, but, "in passing", it occurred to me that we haven't heard much/anything from Octagon in the way of f/w updates & so on the 88/89 (etc.) series boxes.
I will using my SX88+ for quite a time yet until I learn enough about the Combo (the first Android Rx I've had) and so I'm wondering if there seems likely to be any more "stuff" for the 88 etc series in the piepline??
Anyone have any "ideas"??
Has anyone else noticed that Octagon appear to have ceased posting info here on new firmware for (at least) this receiver?
TBH, I haven't used it much at all over the last few months as we've had a lot of other issues to deal with, but, just now, I fired it up and checked the f/w situation - and found that an update got released about a month ago, and which I have thus just loaded on 88+!
I suspect that all the "enthusiasm" for the GTMedia Combo has led to this and related Octagons being overlooked!
BTW: I never managed to get the hang of the Combo - just "too much" to learn at a time when other things were/are more important to us.:rolleyes:
I loaded up the Open8 firmare direct from the Octagon website a fortnight ago as I was getting fed up with the combo video lag.
Quite impressed with it so far, though I only put the 4008 back on the shelf at the beginning of the week.
