FreeSat no signal on any channels
pwl2706
Panasonic Dual tuner Freesat HDD DVD Recorder
London, UK
Last night everything was fine
This morning, no signal on either Sat input, on any channels
No strong wind or rain in Ealing, London
no changes to the box, cables unchanged
is it just me?
Yes, just you (unless you are in an apartment block).
pwl2706
London, UK
thanks, what can I do - would a full retune be worth it?
Doubtful, as it seems the signal path from the dish to your box has been disrupted.
Do you have your own dedicated dish or are you on a communal system?
pwl2706
London, UK
it's a dedicated dish, brand new in April, installed on the balcony
Ok. Then I suggest you look to see if it appears to have gone out of alignment (Sagged? Been knocked? Been blown askew?), and also check the cable connections (partial detachment? Braid shorting to centre core at each end?).
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
Even a cat, walking by, could have changed the LNB skew?
