name?
I have not found a satellite where on the same transponder there are T2Mi with different PIDs.How does blindscan work on transponders where there are more T2-MI pids? In my region, there is a minimum of T2-MI transponders per 100cm dish.
<transponder frequency="12585000" symbol_rate="35500000" polarization="0" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="20" t2mi_plp_id="0" t2mi_pid="4646"/>
Just as useless as this messageuseless to insert a page when the most important thing is not there - the T2-MI pid value
Eutelsat 5 West A / Eutelsat 5 West B @ 5° WThe orbital position of the satellite is also missing...![]()
0dde3129:0110:0000
s 12585000:35500000:0:2:-50:2:0:1:2:0:2:20:262140:1
#DESCRIPTION --- Mediaset T2MI mis20 ---
#SERVICE 1:0:1:869:3129:14:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12585plp0:Focus (provvisorio)
#DESCRIPTION Focus (provvisorio)
#SERVICE 1:0:1:BCC:3129:14:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12585plp0:20Mediaset HD
#DESCRIPTION 20Mediaset HD
#SERVICE 1:0:1:C80:3129:14:0:0:0:0:http%3a//0.0.0.0%3a9999/rtrs/12585plp0:Test HEVC Main10
#DESCRIPTION Test HEVC Main10
#SERVICE 1:64:47F:0:0:0:0:0:0:0::-- SID MIS20 --
#DESCRIPTION -- SID MIS20 --
#SERVICE 1:0:1:320:110:0:DDE3129:0:0:0:
-- RL Piemonte 1 5.0W
f12585piem0 = make_t2mi_decap({
name = "12585H T2-MI PLP0",
input = "http://127.0.0.1:8001/1:0:1:320:110:0:DDE3129:0:0:0", -- required
plp = 0,
pnr = 0,
pid = 4096,
make_channel({
name = "12585piem0 ", input = { "t2mi://f12585piem0", },
output = { "http://0.0.0.0:9999/rtrs/12585plp0", },
So go through it over & over again until you have figured out where the problem is - we provide general guidance only - if you dont want to do the hard work yourself & want to rely on others doing the work then you do without.this config from ciefp but not work
So learn how it works - Enigma operating systems are bloody hard work to get your head around, but if you want to get the most out of a receiver you have to spend MONTHS working on it. There are no shortcuts here - only you can decide whether you want to put the effort in@Analoguesat
the error how to get full info for channel in ts file
in enigma2
in enigma2 not get full info for channel and not have much experience in editing and adding channels
the author should be consultedthis config from ciefp but not work
work wit this config
www.satellites.co.uk
