Multistream blindscan
scannie
110 cm triax, tbs 5927
Roermond, NL
Is it possible to find multistreams via blindscan?
Do I need a specific image or add-on?
EnoSat
enosat.euweb.cz
Slovakia
scannie
Roermond, NL
Can you explain how?
Mickha
North West
Do you have a suitable LNB, and 4K receiver?
scannie
Roermond, NL
I forgot to mention.
Yes, an Octagon SF8008.
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
With OpenATV
Menu —> Setup —> Reception —> Blind scan
For 5°W & 33°E a 110 cm dish is O.K.
For 14°W you will need a bigger dish in order to lock all the multistream channels.
MCelliotG
Thessaloniki, Greece
To save any further confusion... o_O
Octagon SF8008 DOES NOT blindscan multistream (MIS) frequencies, only T2-MI and these are not multistream transmissions.
The only E2 receivers that can blindscan MIS are the ones equipped with an Availink tuner (such as Edision OSmio 4K) and potentially an MS88R6060 tuner (but I'm not sure if this is activated in E2).
scannie
Roermond, NL
@ MCelliotG: MIS is indeed what I mean. The Edision OSmio 4K isn’t available anymore.
Do you know an alternative?
MCelliotG
So far, no, I'm not sure if these Multibox receivers that some of them are equipped with the MS tuner are able to blindscan MIS. The tuner is capable and fast, but I'm not sure if the manufacturer has released drivers that enable this feature.
LeBelge
Belguim
These are avalable at amazon de
Edision OS Mio+ 4K 185€
Edision OS Mini 4K 140€
they will scan every thin, I have got them
scannie
Roermond, NL
Are you sure these models are able to blindscan MIS?
LeBelge
Belguim
Yes I am sure, look for the satellite at 33°E
Voilà
p.s.
this scan is with Edision OS Mini 4K, the other Edision OS Mio+ 4K will do the same.
