13.0°E HotBird 13C
EnoSat
enosat.euweb.cz
Slovakia
After updating the firmware of the AVL6261C tuner, reception is also possible on receivers with this tuner
EnoSat
enosat.euweb.cz
Slovakia
Doesn't SF4008 use Si21662 ?
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
Yes, sorry, you're right.. maybe a solution in the future, we never know :)
There has been no support for the SF4008 for a long while.
Enjoy the receiver for it's quality build and onboard storage.
ac1139
120 cm PF, 180 cm offset.
100 km north of Vienna
My VU+ ZERO 4K doesn't work.
What is S2X "short frame" used for?
Feeds, tests?
EnoSat
enosat.euweb.cz
Slovakia
more space for data :-woohoo
stpierre
Multisat Indoor Home Made 10 LNB 52°e > 5°w + Fibo 90cm USALS = 68°e > 45°w
Belgium
Hi Enosat,
Thanks for your work !
I have an Edision Mio 4K with AVL6261C tuner, but how to update this firmware ?
Have tried with classical update SatDream GR but no result with SDGR 6 and 8 !
jsda30
edision os mio 4k
spain
tompouce
Belgium
Yes, the SF4008 is a very good one ! it will be perfect if there is an upgrade too for the tuner SI 21662 D60; see these specifications !
  • Si21662-D60_short.pdf
EnoSat
enosat.euweb.cz
Slovakia
jsda30
edision os mio 4k
spain
jsda30
edision os mio 4k
spain
stephan94
Bavaria
Hello Enosat ,
Is it normal that the blindscan doesn't work anymore after this update ? Edision mio4K (without +)
EnoSat
enosat.euweb.cz
Slovakia
report on github, for me blinscan works better than for the update, since it already finds ShortFrame transponders
PS: If you have backed up the FW floods, it is not a problem to go back and check if it affects BlindScan
<?xml version="1.0" encoding="iso-8859-1"?>
    File created on Piatok, 13 of január 2023, 02:22:41
    using osmio4kplus receiver running Enigma2 image, version 6.2,
    build 011, with the blindscan plugin
    Search parameters:
        Tuner A: Availink AVL6261 (DVB-S2X)
        Satellite: Yamal401 (90.0E)
        Start frequency: 10700MHz
        Stop frequency: 12750MHz
        Polarization: vertical and horizontal
        Lower symbol rate: 1000
        Upper symbol rate: 60000
        Only save unknown tranponders: no
        Filter out adjacent satellites: up to 3 degrees
        Scan duration: 492 seconds
<satellites>
    <sat name="Yamal401 (90.0E)" flags="0" position="900">
        <transponder frequency="10952000" symbol_rate="2537000" polarization="0" fec_inner="2" system="1" modulation="2" />
        <transponder frequency="10972000" symbol_rate="11200000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="11070000" symbol_rate="5000000" polarization="0" fec_inner="3" system="1" modulation="5" is_id="0" />
        <transponder frequency="11153000" symbol_rate="5000000" polarization="0" fec_inner="4" system="1" modulation="2" is_id="0" />
        <transponder frequency="11169000" symbol_rate="17500000" polarization="0" fec_inner="2" system="1" modulation="4" is_id="0" />
        <transponder frequency="11187000" symbol_rate="10000000" polarization="0" fec_inner="3" system="1" modulation="2" is_id="0" />
        <transponder frequency="11213000" symbol_rate="9000000" polarization="1" fec_inner="3" system="1" modulation="4" />
        <transponder frequency="11225000" symbol_rate="26670000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11236000" symbol_rate="7950000" polarization="1" fec_inner="3" system="1" modulation="4" is_id="0" />
        <transponder frequency="11265000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="1" is_id="0" />
        <transponder frequency="11266000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" is_id="0" />
        <transponder frequency="11295000" symbol_rate="11451000" polarization="0" fec_inner="3" system="1" modulation="4" is_id="0" />
        <transponder frequency="11297000" symbol_rate="17406000" polarization="1" fec_inner="2" system="1" modulation="1" is_id="0" />
        <transponder frequency="11345000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
        <transponder frequency="11346000" symbol_rate="14000000" polarization="1" fec_inner="2" system="1" modulation="4" is_id="0" />
        <transponder frequency="11359000" symbol_rate="9166000" polarization="1" fec_inner="2" system="1" modulation="4" is_id="0" />
        <transponder frequency="11412000" symbol_rate="6650000" polarization="0" fec_inner="1" system="1" modulation="1" is_id="21" />
        <transponder frequency="11426000" symbol_rate="32727000" polarization="1" fec_inner="0" system="1" modulation="5" is_id="0" />
        <transponder frequency="11429000" symbol_rate="5000000" polarization="0" fec_inner="3" system="1" modulation="5" is_id="0" />
        <transponder frequency="11439000" symbol_rate="10000000" polarization="0" fec_inner="0" system="1" modulation="5" is_id="0" />
        <transponder frequency="11488000" symbol_rate="5700000" polarization="0" fec_inner="6" system="1" modulation="2" is_id="0" />
        <transponder frequency="11496000" symbol_rate="4067000" polarization="0" fec_inner="3" system="1" modulation="2" is_id="0" />
        <transponder frequency="11610000" symbol_rate="4120000" polarization="0" fec_inner="3" system="1" modulation="1" is_id="0" />
        <transponder frequency="11629000" symbol_rate="4500000" polarization="1" fec_inner="6" system="1" modulation="2" />
        <transponder frequency="11649000" symbol_rate="2170000" polarization="0" fec_inner="3" system="0" modulation="1" />
        <transponder frequency="11664000" symbol_rate="13090000" polarization="1" fec_inner="7" system="1" modulation="1" is_id="21" />
        <transponder frequency="12535000" symbol_rate="15000000" polarization="1" fec_inner="4" system="1" modulation="5" is_id="0" />
        <transponder frequency="12655000" symbol_rate="3375000" polarization="1" fec_inner="3" system="1" modulation="2" is_id="0" />
        <transponder frequency="12668000" symbol_rate="5250000" polarization="1" fec_inner="2" system="1" modulation="1" is_id="0" />
    </sat>
</satellites>
stephan94
Bavaria
Hello Enosat ,
yes you are right, the blindscan works, only this particular transponder ( 11199V 34285) is not found
it's really not a big deal.
Thank you for your work.
jsda30
edision os mio 4k
spain
with the new firmware i get at 8w some radios with 890 SR... so are a good news for this tuner!!
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Ireland
the frequency is working again
:tv: : Eutelsat Promo TV
Transponder: 11200 V 27500 DVB-S2/16APSK 3/4
Provider: aCAN Group
stpierre
Belgium
Hello,
I have SR 34283 !
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Working with dm900 si2166d twin dvb-s2x tuner
