Red alert
- Dec 21, 2019
- Age
- 39
Inverto ultra 0.2db, Edision Mio 4K, 1m Gibertini XP on Superior Dark Motor.
R.I.P -> Technomate M3 and Stab HH100.
- Manchester
Hi all,
Purchased a superjack dg320 about a month ago and was working well until today. The motor looks new and not used, came in box. Motor looks similar to Alsat superior motor and was interested to buy this and try. I installed the motor with new F connectors and re made the cable connections to motor and receiver aswell as lnb. For some reason the motor will only move if I use the “step” function in the positioner setup. Move East/West does not work neither does “goto 0”. I have tried moving with USALS and Diseq C 1.2. I have also tried a few images. I even connected a Octagon SX89 WL to test and the same thing. Motor will not move.
I have been outside to reset the motor and that works and the led’s flash after 3 seconds. If I press the manual east west button the motor will only step east/west. It will only move east if I put slight pressure on the dish to push it east and press the east button. I have also tried disconnecting the lnb and still the same.
Any ideas what I can try next. Otherwise will have to put the superior motor back.
