Channel 5 on 11306 H
my sony bravia 4k has a sat tuner as does my samsung qled
And I have several Panasonic TVs with Freesat tuners in France. Care that you get Freesat, if that's what you want, as there are some with simple satellite tuners.
curly wurly
180cm dish - Pace 430N - Inverto Black Ultra LNB
Northern Tuscany, near Viareggio, Italy
Checked it on all my receivers now and there is quite a difference on all three receivers so it's not related to a specific recevier.
11306 H used to be around 9,5 - 9,7 db. 11306 V, 11344 H/V used to be and still are around 10,9 - 11,1 dB.
Now is 11306 H at the same level as the others. Checking it now and it is at 11,0 dB.
So not much difference at all really.
Nalleman
Motala Sweden
Sweden
The reason I started this tread was the fact 11306 H was weaker than 11306 V and 11344 V/H.
Now when this is fixed I only wanted to mention it.
Up to 1,5 dB more makes the margin in bad weather quite a bit better.
A good thing is 11306 H uses FEC 2/3 whilst the other use FEC 5/6.
Can you receive anything from 11306 V and 11344 V/H?
ocean04
Vaasa
Western Finland (63N 22E)
Not much improvement here, 11306H signal is poor, only 3.0db currently.
Improves little when weather gets colder. 10964H signal was much better here.
Nalleman
Motala Sweden
Sweden
Yes 10964 H was a bit better here too.
The weakest here by far is 11053 H which I can't get all day.
The second weakest is 12129 V which comes in at about 9 dB.
Not sure if 12129 is on 2E or 2F. Flysat says 2E and Lyngsat 2F.
ocean04
Vaasa
12129V is 2E, easy to see difference here, currently 6.8db.
For comparison 12382H 7.2db (2F)
I believe one reason 11306H is weak here, is because 11264H is so strong and close
Fisty McB
See my signature...
County Tyrone, N. Ireland
This is me thinking aloud here, but could one reason 11306H from Astra 2F has in having reception issues in parts of southwest Europe is because of co-channel interference from 11310H from Badr on 26E? I do know that where I live (Northern Ireland) , there are similar issues that I have experienced albeit in reverse (strong Astra 2 signals interfering with weaker Badr signals).
curly wurly
No, no signal at all.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
I sent again to check if I can catch astro 2f from my location. I succeeded again on gibertini 150 and bulleye lnbs.
curly wurly
Whereabouts are you exactly?
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica -Slovenija
Not surprising that you have a weak signal on the UK beam in SlovenijaAstra-2F-UK.png
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
I'm happy to create reception. I don't watch programs much, but I'm happy if I succeed in Lock because it's a challenge for me. In winter, the signal will be a little better - I'll see how much progress there will be when I install the 1.8m Laminas - I'm counting on around 2 dB improvement.
curly wurly
That's interesting. My dish is an offset 1.80 - don't remember the make, in Northern/ central Italy.
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
And you have signal?
curly wurly
I get BBC, ITV etc but no Channel 5 and I don't have enough signal for HD.
jambon550192
Paphos cyprus
1m orbit h2h manhatton plaza cm1.8 inverto quad with cm feedhorn at 7w,tm 6900 super hdfixed 1.5 prime focus on 16e with tring diseqc x4 at 7w v/h 13e 19.2e 28.2e with 3 quad smart titanium gold 0.1 lnbs ,TM-3000d 2.5 precision at 25.5e
kent
Going by this footprint does this mean parts of greenland can get sky
Beli1910
Sevnica-Slovenija
Triax 110-,motor
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Probably yes. If you look at the beam, I'm at least 1000 km outside of it, but my reception is at the lower limit.
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
I have max 4.5dB on Channel 5 with Gibby, no reception most of the day..
