Advice Needed Image for Edison MIO+ MS 4k box
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
Hi everyone,
I just bought an Edison Mio+ 4k MS from amazon. Will take a week to get here, which is unusual for amazon. I expect to brick it within a week. I am good at breaking everything.
Next step is an image to install. It probably comes with OpenPli pre-installed, but:-
I wish to:
- modify the scan steps in MHz, and the symbol rate interval. By increments of 0.25 Mhz would be excellent. Can I do this in the blindscan plugin?
- see if I can get a Fransat PC7 activated card working. Does oscam do this or is CCcam better? (I am wary of the closed source nature of CCcam)
- I want to plug in my external USB disc into a USB port and watch my mp4 , avi files already on it. I think the disc is formatted as exFat.
OpenVix 6 looks really good. I very much like their gui.
Question:
Can I do multiboot providing one slot with OpenPki and a second slot with OpenVix?
Regards,
S!
EnoSat
enosat.euweb.cz
Slovakia
yes
Using the old SDG6 you can get a full 64b image, the others were only 32b.
In addition to enigma, it is also possible to try neutrino in multiboot.
stephan94
Bavaria
Hallo Enosat ,
What is this image for the Edison Mio+ 4k "Tangos rev20695"?
I've never seen it
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
You are all wrong,
my 4 receivers Edision have the latest version of the original OpenATV and they don't need any Fransat. You can even keep the version it comes with.
Multistream is enough for the french TV channels from 5°W.
The good news is that you will finally have the right receiver for your needs = Edison Mio+ 4k.
sophie101
* Currently
belgium
You are all wrong,
Thank-you. You are right I got the receiver delivered today.
Came with pre-installed OpenATV 6.4 image.
Got some strange teething problems with this:
1) Wireless: The wireless scan finds approximately 50% of the SSIDs in my area, and it does not find my SSID (AES WPA2 passphrase). I tried to enter it manually but made a mistake, and now have the wrong SSID. Where is the delete button to remove the unwanted charachers?
2) Favourite list: How can I add the current channel we are watching to the Favourites list? I tried lots of buttons.
3. How can I disable the time/date/temperate settings from the OSD?
4. I did a blind scan of 5W and got the RAI multistream channels, but did not get any French TV multistream.
Any ideas?
Many thanks for any answers. e.
LeBelge
Belguim
j'ai pas le temps maintenant il y a The Voice UK à 21 heure
mais le Edision va marcher très bien
sophie101
* Currently
belgium
Pas de soucis. No doubt it will. Just some teething problems :)
Oddly, I cannot find any channels on 28.2e or 19.2e or 13e. I only have got 5w. Even though I have the Disque 1.0 set on these. I took the defauls. DVB-T RTBF came up just fine.
Oh wait. I got my LNBs in the wrong order.
Even so, I still just get 5W. I did a blind scan of what should be 5w 13e 19.2e and 28.2e and just got 188 channels from 19.2e, which look surprisinly like the channels on 5W.
I have each LNB set to the same as this except for the LNB number.
Config mode: advanced
Sat:  28.2e
LNB: LNB4
Prioroty: Auto
LOF: Univeral LNB
Voltage Mode: Polorisation
Tone mode: Band
Increase voltage: No
DISEqC mode: 1.0
Fast DISEqC: yes
Toneburst: non
DISEqC 1.0 command: none
Sequence repear: no
Force legacy signal stats: no
EnoSat
enosat.euweb.cz
Slovakia
It probably didn't switch DiSEqC
Manikm909
Small'ish Dish Man
Kent, UK
EnoSat
enosat.euweb.cz
Slovakia
Sat:  28.2e
LNB: LNB4
Prioroty: Auto
LOF: Univeral LNB
Tone mode: Band
DISEqC mode: 1.0
Fast DISEqC: yes
Toneburst: non
Sequence repear: no
If you use only 4 LNBs on 1.0, set:
simple
DiSEqc A/B/C/D
PS: you have not defined the diseqc command in the advanced settings
sophie101
* Currently
belgium
I just changed it to simple mode, and still got 5W channels when I blind scanned (FTA only) 19.2e with this configuration:
Config mode: simple
Mode: DISEqC A/B/C/D
Port A: 5w
Port B: 13e
Port C: 19.2e
Port D: 28.2e
Set voltage and 22khz: Ja
Send DISEqC only on satellite change: Nein
Next I tried an automatic scan ( for some reason it thinks Amos 4w is also present, and I cannot see how to delete it. It's not configured) and got the channels from 5W from all LNBs.
If I pull out the cable and plug it back into my TV set built in DVB-S2 tuner, then all of the channels are there, but not on the Edision.
EnoSat
enosat.euweb.cz
Slovakia
try
Port A - auto
Port B - auto
Port C - auto
Port D - auto
and push yellow - Auto Diseqc
sophie101
* Currently
belgium
try
Port A - auto
Port B - auto
Port C - auto
Port D - auto
It displayed for each search: Tuner status: FAILED.
When it had finished it listed each port as Nichts angescholossen
I plugged the coax back into my TV and can watch all the channels from all of the LNBs as before. It is the Edision and not the cable.
EnoSat
enosat.euweb.cz
Slovakia
sophie101
* Currently
belgium
You have a different one to mine.
sophie101
* Currently
belgium
I am doing a Factory Reset.
EnoSat
enosat.euweb.cz
Slovakia
Ah, you used OpenATV, I prefer to use OpenVix
In OpenATV push green (Save) and Auto Diseqc will start
