LeBelge
- 2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
- Belguim
Indeed, difficult to obtain with a 60 cm dish and these rainy days ;)SR-29500 - minimum for LOCK - 11 dB
Next step is to fix the audio.
The Edision is very low even at 100%, which means I have to turn the TV set volume up very high. Because I suffer from severe Tinnitus I end up with a loud volume of background frequencies that really hurts my ear, and makes the tinnitus louder than the audio.
Thanks for this, but I won't be spending more money for timebeing. My TV is already loud enough.Pour éviter de déclencher des crise d'acouphène il vaut mieux utiliser des vrais enceintes acoustique actives ( avec un amplificateur intégré et une télécommande ).
Dans une enceintes acoustique il y a de la ouate ou de la mousse, comme ça:
alors que dans les soundbars il n'y a pas de place pour la ouate.
Donc = une mauvaise qualité sonore.
No, definatly MBR:Your USB is probably not formatted as MBR, but as GPT
Don't forget to extract it correctly on the USB
# gpt -r show /dev/disk2
start size index contents
0 1 MBR
1 31
32 30031840 1 MBR part 11
# find . -ls
2 16 drwxrwxrwx 1 _unknown _unknown 8192 Nov 30 17:11 .
124 16 drwxrwxrwx 1 _unknown _unknown 8192 Nov 30 17:11 ./osmio4kplus
141 16 -rwxrwxrwx 1 _unknown _unknown 68 Nov 12 10:55 ./osmio4kplus/imageversion
179 9024 -rwxrwxrwx 1 _unknown _unknown 4618272 Nov 12 10:55 ./osmio4kplus/kernel.bin
743 236272 -rwxrwxrwx 1 _unknown _unknown 120964372 Nov 12 10:54 ./osmio4kplus/rootfs.tar.bz2
this for multiboot, it will only work in a running image and will have to select the slot in which it is to be installedCode:# find . -ls 2 16 drwxrwxrwx 1 _unknown _unknown 8192 Nov 30 17:11 . 124 16 drwxrwxrwx 1 _unknown _unknown 8192 Nov 30 17:11 ./osmio4kplus 141 16 -rwxrwxrwx 1 _unknown _unknown 68 Nov 12 10:55 ./osmio4kplus/imageversion 179 9024 -rwxrwxrwx 1 _unknown _unknown 4618272 Nov 12 10:55 ./osmio4kplus/kernel.bin 743 236272 -rwxrwxrwx 1 _unknown _unknown 120964372 Nov 12 10:54 ./osmio4kplus/rootfs.tar.bz2
ofgwrite -m4 /media/usb/osmio4kplus
ofgwrite -r -k -m4 /media/usb/osmio4kplus
can u not use Windows. bootcamp.this for multiboot, it will only work in a running image and will have to select the slot in which it is to be installed
from terminal for slot4:
orCode:ofgwrite -m4 /media/usb/osmio4kplus
Code:ofgwrite -r -k -m4 /media/usb/osmio4kplus
# cat recovery_osmio4kplus_READ.ME
***** ATTENTION *****
The RECOVERY is only required for new installation of the osmio4kplus
The openvix-6.4.009.release-osmio4kplus_recovery_emmc.zip deletes all images including the multiboot images
let me know if you get the issue i do, if you utilise two tuners....TUNER_A just loses signal, i.e nothing after a day or two ..very odd - only a reboot brings it back! doesnt happen with openatv, but i hate openATVJob done :-)
Actually I have the same setup problem I had with openatv. Automatic on tuner A cannot find any birds. Yet the TV builtin tuner finds everything.let me know if you get the issue i do, if you utilise two tuners....TUNER_A just loses signal, i.e nothing after a day or two ..very odd - only a reboot brings it back! doesnt happen with openatv, but i hate openATV
lets not get the problem mixed up!Actually I have the same setup problem I had with openatv. Automatic on tuner A cannot find any birds. Yet the TV builtin tuner finds everything.
Admittedly today is a bad day to scan given the town is shrouded in a thick layer of fog!
I already gave you the file for OpenATV 7.3OpenATV 6.5 does not cut it for me.
1, The openvix-6.4.009.release-osmio4kplus_recovery_emmc.zip deletes all images including the multiboot images
I know, but I hated using openatv. Openvix 6.4 is working now.I already gave you the file for OpenATV 7.3
you do not need other images
if OpenATV works for me it will work for you too
just ask questions how to flash it
