Advice Needed Image for Edison MIO+ MS 4k box
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
The LNB for 5°W is not even in cetral position on this ridiculous small dish
WaveFrontier Toroidal T55 (67cm x 53 cm)
At least a 95 cm antenna must be installed ( Triax TD88 ).
With a bigger one ( 100 - 105 - 110 cm ) the signal will be even better.
LeBelge
Belguim
Next step is to fix the audio.
The Edision is very low even at 100%, which means I have to turn the TV set volume up very high. Because I suffer from severe Tinnitus I end up with a loud volume of background frequencies that really hurts my ear, and makes the tinnitus louder than the audio.
Pour éviter de déclencher des crise d'acouphène il vaut mieux utiliser des vrais enceintes acoustique actives ( avec un amplificateur intégré et une télécommande ).
To avoid triggering tinnitus seizures, it is better to use real active speakers (with a built-in amplifier and a remote control).
Dans une enceintes acoustique il y a de la ouate ou de la mousse, comme ça:
In an acoustic speaker there is wadding or foam, like this:
alors que dans les soundbars il n'y a pas de place pour la ouate.
Donc = une mauvaise qualité sonore.
Whereas in soundbars there is no room for wadding.
So = poor sound quality.
sophie101
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
belgium
Thanks for this, but I won't be spending more money for timebeing. My TV is already loud enough.
The problem is the satellite audio. I get it from most channels, but never from my MP4,MKi,AVI recorded films.
It is the same on every TV I tried, and every decoder.
Its the same with audio on telephone calls: OK over GSM. Tinnitus over WhatsApp/Facetime.
I suspect that the audio is compressed using a method that triggers the T. I know my Tinnitus is often triggered with sounds above 12,000hz.
So, I have to play with the Codec and audio on the Edision image.
Also, there is a severe difference in audio on the openatv 6.4 I have:
Some channels on like 28.2 Channel4, Film4, BBC etc are very audiable at a low volume, but the German channels on 19.2e are barely audible and I have to turn up the volume much louder, which amplifiers other hidden noise which triggers tinnitus.
I have stopped using the Edison for now, because of this. The builtin TV receivers I have is better - My old Philips TV from 2018 does not have this problem. Perhaps it uses an older codec for this.
What a beautiful wooden TV stand they have!
sophie101
* Currently
belgium
OpenATV 6.5 does not cut it for me. Illogical set-up.
I tried to install openVIX 6.4 last night several times, and no luck. The Edision finds the openvix usb image, and asks me to hold down the OK remote control button for ten seconds ( which for ten seconds?), but immediately boots back into OpenATV when I press OK.
Looks like I will have to use OpenPli instead. Question is do I flash the multiboot image first to get multiboot, *or* do I flash the standard usb image initially and then the multi-boot image on top. No instructions on their site.
EnoSat
enosat.euweb.cz
Slovakia
Your USB is probably not formatted as MBR, but as GPT
Don't forget to extract it correctly on the USB
sophie101
* Currently
belgium
No, definatly MBR:
# gpt -r show /dev/disk2
     start      size  index  contents
         0         1         MBR
         1        31
        32  30031840      1  MBR part 11
# find . -ls
     2       16 drwxrwxrwx    1 _unknown         _unknown             8192 Nov 30 17:11 .
   124       16 drwxrwxrwx    1 _unknown         _unknown             8192 Nov 30 17:11 ./osmio4kplus
   141       16 -rwxrwxrwx    1 _unknown         _unknown               68 Nov 12 10:55 ./osmio4kplus/imageversion
   179     9024 -rwxrwxrwx    1 _unknown         _unknown          4618272 Nov 12 10:55 ./osmio4kplus/kernel.bin
   743   236272 -rwxrwxrwx    1 _unknown         _unknown         120964372 Nov 12 10:54 ./osmio4kplus/rootfs.tar.bz2
Although macos always puts those extended attribute for HFS ._ files everywhere, which I think I removed before I tried. Not that those should matter.
EnoSat
enosat.euweb.cz
Slovakia
# find . -ls
this for multiboot, it will only work in a running image and will have to select the slot in which it is to be installed
from terminal for slot4:
ofgwrite -m4 /media/usb/osmio4kplus
or
ofgwrite -r -k -m4 /media/usb/osmio4kplus
sophie101
* Currently
belgium
I don't think this can help me, because I still have got openATV stuck on my edision :)
Do I install openvix or openpli normal version first, and then multiboot editions later? This is unclear.
Does the zip used for the initial installation need to have an emmc.img file in it?
It's weird because the OpenVix zip is listed as a recorvery image as opposed to an initial installation but has an emmc.img file in it.
Openvix 6 4 009 Release Osmio4kplus Recovery Emmc (128.8M)
Yet there is a USB version. Not idea what the USB version is for. I thought it was for flashing using the USB, but it does not have a emmc.img in the zip.
Openvix 6 4 009 Release Osmio4kplus Usb (116M)
Manikm909
Small'ish Dish Man
Kent, UK
or
can u not use Windows. bootcamp.
ive never had an issue putting an image on using USB stick, you only really need to press red button for a second or two and it starts installing.
sophie101
* Currently
belgium
Thank goodness for Readme files!
# cat recovery_osmio4kplus_READ.ME
***** ATTENTION *****
The RECOVERY is only required for new installation of the osmio4kplus
The openvix-6.4.009.release-osmio4kplus_recovery_emmc.zip deletes all images including the multiboot images
Mystery over. I will flash this.
sophie101
* Currently
belgium
Job done :-)
sophie101
* Currently
belgium
Manikm909
Small'ish Dish Man
Kent, UK
Job done :-)
let me know if you get the issue i do, if you utilise two tuners....TUNER_A just loses signal, i.e nothing after a day or two ..very odd - only a reboot brings it back! doesnt happen with openatv, but i hate openATV
sophie101
* Currently
belgium
Actually I have the same setup problem I had with openatv. Automatic on tuner A cannot find any birds. Yet the TV builtin tuner finds everything.
Admittedly today is a bad day to scan given the town is shrouded in a thick layer of fog!
Although it's never obvious to me which tuner I am configuring in the set-up wizard because I do tunerA and then it decides to scan tunerB... gaaah :-) :-)
Anyway, signals coming in. Will re-scan when we have a blue sky day.
Manikm909
Small'ish Dish Man
Kent, UK
lets not get the problem mixed up!
signal is there, for a day or so on TunerA - lets say hotbird at 16db on RAI1 - TunerB on 28.2e - all good for maybe 24 hours
then when i come back, TunerA reports 0% signal, TunerB - fine....
only a reboot brings back RAI1 on TunerA
LeBelge
Belguim
I already gave you the file for OpenATV 7.3
you do not need other images
if OpenATV works for me it will work for you too
just ask questions how to flash it
Manikm909
Small'ish Dish Man
Kent, UK
i prefer Vix over OpenATV also.
EnoSat
enosat.euweb.cz
Slovakia
sophie101
* Currently
belgium
I know, but I hated using openatv. Openvix 6.4 is working now.
