Advice Needed Motorising a Zone 2
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Hi all,
My uncle has asked me to supply and fit a basic motorised system for reception of 28.2e, 23.5e, 19.2e, 16e and 13e.
The slight issue is my aunt. She is completely against it and won’t let him put up my old 85cm Gibertini as it’s a big white eyesore:oops:
So I have suggested motorising a Sky Zone 2, we have shown her a couple of local ones and she’s said that’s ok.
I know reception of 16e will be difficult on it and he is aware of that, it’s 19.2e, 13e and 28.2e he really wants. I have an old TM2300 he can have so it’s the dish.
I keep seeing 80cm Zone 2’s advertised. Do these actually exist?
Secondly, I have been on Purplesats website and it seems he uses a particular Zone 2 for motorised installations. The rear bracket seems to clamp straight onto the motor on the one he uses.
Any idea what MK Zone 2 I need?
Mooncamm
1 metre Gibertini dish, Octagon SX88 Receiver
Lincolnshire
Hi all,
I am doing the same as you. I have to wait until the warmer weather as I am retired and my bones can't do the winter. I have enjoyed KU band satellite for 35 years. I have a 1 metre Gibertini dish as my main dish and wish to remain within the law so my second dish is going to be a Triax 60cm dish I think on a Technomate motor. I have also bought a couple of lnb multi holders so if I change my mind I can go that route. If I do, I want 28 east, 19 east,13 east and I might throw in 23.5 east as its a decent space to fit ordinary lnb's into as I don't have the slim lnb's. If you google World of Satellite they have 60 cm & 80 cm dishes. (Last time I browsed their site) When I have used a 60 cm dish in the past, its was very much a back up dish, and rain can easily wipe out signals. It is better than nowt if the main 1 metre dish gets into trouble. Good luck. :)
I have installed a couple of Zone 2 dishes on Moteck clone motors, I think I was able to bolt the wall mount version using an exhaust clamp but I will need to look back through some receipts to verify.
I have mk2 Zone 2s, the original pole is 1.25", the Technomate TM2600's shaft is too large - around 50-55mm IIRC.
Offtensive
Midlands
@Ferret has done this for someone iirc
that' just marketing. I think they are like 54 or 56cm x 74 or 76cm
cwsat
Midlands
There are a couple of motorised Zone 2’s here.
They all look the same MK of minidish to me.
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
Why don't you just put a T90 antenna. It should be sufficient for your wishes and needs. It will definitely give much better results than a 60cm antenna on a Diqec motor.
cwsat
Midlands
Budget and it’s a bigger eyesore than my Gibertini.
Fisty McB
See my signature...
County Tyrone, N. Ireland
My initial thought is that most Diseqc motors' mounting poles will be too thick for a Sky Zone 2 dish mount. Is a universal perforated/mesh 60-65cm dish a possible alternative?
Not to mention that from my own experience a Sky Zone 2 might be touch & go at 16E for some channels, or at least haven't much of a rain fade margin?
cwsat
Midlands
My initial thought is that most Diseqc motors' mounting poles will be too thick for a Sky Zone 2 dish mount. Is a universal perforated/mesh 60-65cm dish a possible alternative.
It will be marginal on 16e but he’s aware of that. I could never pick it up on my Triax TD65.
There are photos of zone 2’s mounted to diseqc motors on the purplesat link I provided, I am just trying to work out what mark zone 2 dish he used.
Mickha
North West
I set up a Penta 85cm, for my parents, it performs well, and looks good.
cwsat
Midlands
Any idea what mark zone 2 that is?
Fisty McB
See my signature...
I can certainly understand how using a Sky Zone 2 compared to even a perforated 60cm universal dish would look a lot less conspicuous to certain people. I do wonder about the issue of LNB skew when using a Zone 2 in those circumstances though, but not likely to really matter too much for what you/your uncle wants (probably set the skew for 16E with the rest being powerful enough to not be otherwise too important)?
Mooncamm
Lincolnshire
I like that advice and will bear it in mind when I fit my 60cm dish - thanks.
Quite different to mine so likely not a mk2. Looks similar to those still sold new but with only one U-bolt rather than two.
I've lifted the shadows, might help others identify the dish:
Dish
cwsat
Midlands
I think it’s a MK4 Triax with a pole mount?
That image looks like my Raven mk2s, the TM2600 shaft fits inside the bracket but with no space for a U-bolt. TBH I thought all Zone 2s were pole mount but could be wrong.
cwsat
Midlands
I was thinking that. It doesn’t look wide enough. Wonder how they have adapted it to fit.
