Advice Needed Motorising a Zone 2
I was thinking that. It doesn’t look wide enough. Wonder how they have adapted it to fit.
Some DiSEqC motors appear to have a narrower diameter tube. No idea if they are still available anywhere, would quite like one myself.
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
I’ve worked out what I need to regarding the brackets etc.
Do I stay with the Sky LNB?
I have seen mentioned you are better off sticking with the one Sky provide as it’s matched to the shape of the dish. I did see Purplesat using a black ultra though.
If the feed isn't matched (i.e. circle shape) and the Sky LNB can be skewed in the holder it can be used. Due to the motor skewing the dish, the Sky LNB will need to be rotated to compensate, therefore if the feed is matched it will then be in a suboptimal position and in effect no longer matched. Unless you're going to chop off the matched feed and reposition it a universal LNB will probably be better, no harm trying the Sky LNB though - it may perform well enough anyway.
Offtensive
Midlands
How narrow do they go? I have a 90cm stab that I bought as a backup for my technomate which I think is about 40mm.
I don't know but a 40mm one could work if there's still space to fit a U-bolt in. I seem to remember thinking a 1.5" pole would fit which is around 38mm.
Offtensive
Midlands
I might try motorising a spare zone 2 I have one day on that motor. But having said that, I still need to do finish my bisat. :-rofl2
cwsat
Midlands
I think it will be a MK4 I go for so they have an adjustable skew. They don’t have a matched feed horn too as far as I am aware.
I will give the standard Sky quad a go and see how it performs. I have a spare IBU so I can hold that towards the dish and see how it performs before ordering a 40mm adapter.
The good news is the rear of his house is due South and he has absolutely no obstructions.
I’ll start the hunt for a Zone 2 for him and put some photos up when I have ‘created’ a way of mounting it to the diseqc motor.
The easiest way is to retain the existing standoff bracket, though the dish will sit some 200mm to one side of the motor.
For the Triax pole mount Zone 2 the rear of the dish mount does need to be widened slightly.
cwsat
Midlands
Is Sky News International (12418v) a good TP to use when on Thor setting up and tweaking the Zone 2 on the motor?
Or is there something stronger?
That's fine. The usual choice.
Of course, the last bit of tweaking should really be done with a weak signal but I bet few of us bother!
cwsat
Midlands
It wouldn’t shock me if most of the TP’s on 0.8W are weak on a Zone 2:eek:
Offtensive
Midlands
Is that for the zone 1 or 2?
I did motorise a zone 1 before by following @ozumo's diagram.
cwsat
Midlands
Interesting.
That looks easier than the current plan I have.
Basically my plan is to fasten 2x 50mm clamps to the back of the existing minidish mount by removing the 4 nuts. Then use 2x more 50mm clamps for the motor.
cwsat
Midlands
The TM2300 looks wider to me. Hmmm
Offtensive
Midlands
Interesting.
How ferret did it? I used a pole-to-pole clamp before to attach a zone 2 to a scaffold pole. But ferret's method seems simpler and more discrete.
cwsat
Midlands
Yeah pretty much.
My issue with the other method is widening the rear bracket so the diseqc motor will clamp correctly.
Fisty McB
See my signature...
County Tyrone, N. Ireland
From my own recent experience, the 12130 H transponder that broadcasts the Hungarian channel Galaxy 4 was the strongest transponder carrying FTA material, with 12418 V being a little weaker.
For tweaking with a weaker transponder (but still likely to get with a Zone 2 on a dry day at least), I'd then go for 11389 H which carries several Swedish & Norwegian Christian stations FTA.
YMMV.
