- UK
Military parade (red berets), 11681 V 2498 8PSK 5/6 (K24_OB_VAN)
What CPU/GPU are you using to decode the video? I have an i7 6700K 4.0GHz but VLC just gives me a black screen, PotPlayer gives about 22FPS but only uses around 60% processer time, I may have a bottle neck elsewhere but not convinced I'd get the full 50FPS with 100% CPU usage anyway.10967.5V S2X detail in screenshot
Playing with a new set-up: 1.8m PF, TBS6903X
i7-9700 3GHz, 32G RAM, Intel UHD 630 i.e. nothing fancy, an Ebay ex-corporate HP box running W10 2019 LTSC. It's on a 15" 1080P screen and it was not completely smooth when a detailed scene was panned on 13E 4k1 demo as attached . I normally use a 2560x1440 monitor.What CPU/GPU are you using to decode the video?
www.satellites.co.uk
FTV, again12537 V,8000,23/36,(S2X)/16APSK-Nodal FTV, again
at the moment the usual NHL feed (10762 V 30000 8PSK) is FTA and there's a new channel (ESPN EMEA Service 1), but the picture is "jerky".
Can someone check on this?
Tks!
NASCAR showing now has occasional picture freeze here, I've also seen picture breakup once.
