Astra 2F at 28E (at last!)
satelliteman
Those that are using spectrum meters to make any assessment of the new signal, please can you post all measurement parameters; dBuV, SNR, CNR, MER, post / pre BER if anything.
park_gate
1.8M + Pace 2600C1 spain
PO7 Uk and Moraira, Spain
Yes, I'll post later. By the way it's no good looking at Lyngsat or King-of-sat because their transponder list seems to have no relation to what is actually being transmitted in band D from those two satellites.
Thanks for the tip, if you didn't have one I was thinking about creating one from King-of-sat which I think is better than Lyngsat.
But I guess the best thing to do is go to the Sat operators web site and the official info.
You've saved me a load of time.
Terry
Bob Meade
A stanley solutions poor communal system!
Thonpson HD box (with new caps!)
Supanet BB, Long time supporter of offshore radio,
Particularly Radio Caroline.
West Suffolk
11053 is still working fine. It's not changed to 2F it's still on 1N.
I read it had changed but for sure not.
11053 still strong and fine. For sure it's still on 1N.
Yes, here in the Eastern England - I'm getting EXACTLY the same readings on 11053 (95% & 65%signal) as another BBC HD transponder. Odd.
sentaro
120cm Astra@28.2°E - 100cm HB @13°E - 85cm Astra@19.2°E
Italy
Since today the signal even increased a little here :)
SES is fine tuning the footprint, I guess.
I don't know how many earth stations they can rely on but, if they are fine tuning, they could really thank all the reports on this forum (as do I) for helping them cutting out some more unwanted areas :-cry1 . They already performed tests at 43°E to figure out the factual footprint; if they are still not relocating all the TPs I really think they are currently tuning. Btw, what is the reason in your opinion for the signal strenght swing during the day on the fringe areas?
bye
andrewcrawford
scotland
Any Icelandic fishermen on a boat with gyroscopic controlled dishes on the forum?? :D
Seriously I wouldnt have thought there would be many problems in Iceland as the island is more on less on the NW-SE axis of decent reception.
no i mean making it higher power in iceland so taking the power away from the south
dvdfilm
1.5m dish
spain
why isn't the paneuropean beam tested yet? the majority of channels should be broadcast from that,unless ses and sky have changed plans.
For the PSB channels there are many other ways to watch them for those who cannot get the signal
andrewcrawford
scotland
because ses wont be to bothered about that just now its the uk psot that important sicne they need 1n back at 19e
Probably because the spotbeam is the most important one for several of SES-Astra's major customers. (BBC / ITV / C4 & possibly the mickey mouse C5O) If theres a mistake on that beam there are major problems to be overcome.
At the end of the day it doesnt really matter what the coverage across Europe is like on the PE beam as viewers there are outside the official coverage area.
BlindFaith
TBS 5925
Would be a big surprise if we're actually watching 2F_PE_beam and the spot beam still has come up :D
You are an evil evil man B-F :D
dvdfilm
1.5m dish
spain
If they have decided to call it paneuropean beam,it should have relevance to test if the coverage is as predicted
11720h
signal down more 3bb
need 4.5m for now
1.8m cant view in israel now 2a 11720h
mbsnr
Sky+ HD - FTA 43W to 42E
Ireland
11720h
need 4.5m for now
Same for me 11720h no signal.That TP contains SS HD 2... All others around it fine.
BlindFaith
TBS 5925
11720H no change here..
zeeteefje
et9k, T55, 1 meter on rotor
France
11720 at 14.5 dB here.
molhopicante
Dreambox 800SE
Portugal
11720H no problem here on Southeast Portugal.
mbsnr
Ireland
Could be my equipment as I don't have SS sub, so never normally scan or use that TP.
EDIT - it was.... false alarm :-wow...... like Sky were going to move a SS TP anyhow to a narrow beam...
neilD
Freiburg Germany, Engelberg Switzerland
azbox
Germany
Also details from Freiburg Germany (near Swiss/French border) on a VU+ Duo 56 SNR and 95 AGC other BBC HD transmissions were around 65 SNR, AGC was about the same
Hiach
Humax Foxsat HD, Fixed 0.7x0.8m (28.2ºE), Fixed TD54 (19.2ºE), Inverto Black Ultra LNBs.
60.4ºN, 5.3ºE
Never seen that strength on 2A. So it looks like going up to a 1m dish would be acceptable here.
I've done further tuning after loss of signal earlier today.
The dish has now got one single LNB and I don't think it's possible to get it any better with the signal meter on the Foxsat (not the PVR version).
-> I can see the TV from the dish.
LNB skew is also optimized - and makes a huge difference.
Astra 2A 11720H quality 90%
Astra 2F 11023H quality 60%
Astra 2D used to be 90% on a clear day - and was almost never out due to normal rain.
Current antenna gain is close to 37 dBi at 11.7GHz (valid for a Triax TD78)
-> And this is currently not big enough for a wet day, that is if the rest of the channels will be similar when they move.
The big question now is: How big a dish to order?
TD88 is +2dB of gain
TD110 is +3dB of gain
1.2m (134x120cm) is +5.5dB of gain
What is the recommended fading margin?
