..and so it begins ..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So you need to write to Flysat ...................... ^_^
I wouldn't feel confident enough G ..on account I cannot accurately state the transponder frequencies..
Unless I could find a couple of solid reference transponders to calibrate the scale properly.
No easy task with data transponders.
This is where it would be useful to receive Saorsat..as it falls within the limits of the SL3 band B....JUST
That would be a useful reference point..but of course..I'm out of the footprint.
rgds
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hmmm ...looks like I got it fairly close ..
I remembered the scottish beam carries crap ..but is lockable at my QTH ..so used it ..
swung the dish to 9E and managed a lock at 20184 ..V
ie R ..
I guess thats pretty close for a guestimate..
pleased I am ..
The force is with me...
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Got a new mystery to try and solve ..
Assuming Neil has Astra @28.2 East accuratly positioned in the Vbox ..then this which was found approx 10 Vbox clicks west of Astra is one I haven't seen before ..
It could I guess be from 28.2 ..and the positioner is slightly out ..but since Hylas 2 is to the left of Astra ..I don't believe this is the origin ..
Which leaves either Badr ..or possibly 25 East ..or maybe the Astra group itself..
I can't find anything listed ..but the scan is accurate.
Thus it is 19742 ..possibly circular ..though more likely Vertical ..
SR57001 2/3
Suggestions ??
rgds
VS
Is that SR accurate? 57000?!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Can't re-check it CJ ..
although the peak is still present ..the modulation has since ceased ..but locked and checked it twice whilst present ..and Yes the TBS card reported 57001 both times..
Weird stuff eh ;)
SR57001 2/3
Suggestions ??
rgds
VS
Well 2F has a Ka payload so its quite possible you have found a new transmission format at 28E
http://www.ses.com/4628845/astra-2f
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Weird stuff eh ;)
Just to add ..although I cannot currently lock it or indeed get a decent constellation from it ..
Just look how wide this peak is ..
No wonder I got such a high SR
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Also from the same source ..ie point on the arc.
This smaller sadly unlockable peak at 18800 Ka band A
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..and here it is again ..
Now clearly showing a constellation..
The classic signs of it being an unmodulated tansponder ..ie test carrier
rgds
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
It gets worse VS. Getting up from my frequent rests, I lost my balance on Sunday and bruised my foot, now I can't walk much. Need to rest a bit more now.
Trying to keep up with the forum in general and this thread in particular, and want to do some KA experimentation myself, but it's a lost cause until things perk up with me :(
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Sorry to hear that buddy ..I know it isn't going to be a speedy recovery .
These things never are as one gets older.
Chin up..keep taking the pills ..and rest is all you can do.
I hope you get back to the hobby sooner rather than later.
Best regards
Evan
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Crazycat has produced a new version 90 of Crazyscan ..but once again ..I cannot download the needed streamreader uncorrupted..
It appears to be related to his source in Russia..
My ISP messes with the download causing corruption of the rar.
Here is the link
http://crazycat69.narod.ru/sattelite/StreamReaderEx/StreamReaderExEx-BDA.rar
Would someone kindly do as Nelson did ..
Download it and post it to this thread..
rgds
VS
Here you go buddy try this
  • StreamReaderExEx-BDA.zip
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers AS ..
No probs with that..
It's certainly an odd occurrance..and nothing I can do about it..
It only happens when my ISP goes to get the file from his Narod server.
cheers
No prob Evan - cant do much to help identify things in Ka, but I can rescue files for you :D
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I've knocked up a quick chart in paint..to give a quick reference of what lnbs are out there for Ka (various band coverage)
..at least the ones I'm aware of..
Some lnbs only do part coverage..
The Norsats and XMW lnbs are expensive relatively... the PLLs are the MOST expensive ..but both cover entire bands ..wheras your Invertos and Hughes only cover sections of bands..
The DirecTV SL3 covers 2 bands in their entirity ...and you get 2 lnb duplicates per unit ..
Problem is ...the polarity is circular ..but a linear compromise can be reached.
rgds
VS
remlap
Wales
There's also a Triax Soarsat LNB Triax TKT 001 with 40mm neck.
