uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
Retired Mod
www.timo.me.uk
Can I confirm PMT scrambled at moment - ie Enigma2 boxes not clearing?
It's fine on the DRHD F15 so could be, certainly not a key change.
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
can confirm PMT is yet again scrambled. No picture on my Solo2.
robbieb43
London: 1.1m Triax, Stab 100 + 3 fixed 60cm, VU+, Qbox Mini HD, DM800, Echostar HDS600
Canaries: TM 5402, Dm800HD, Qbox Mini HD, DM600, 1.4m, 2 x 1.2M, 1.0m, 0.9m fixed.
London and Canaries (Costa Teguise)
Thanks Kota - save me looking for other issues.
marjanen
Vu+ Uno
Finland
Still down for enigma2. I wonder if its beacuse of the champions league....
Probably not - it was encrypted for much of last year apart from the Olympics
artsmile
Saint-Petersburg
DM800HD SE, 28.2E+19.2E+13E, 27.5W, 36E
Russia
Can't open HD channels with new DR.HD F15 (205P) because it requires video H264 (no audio, no video). How can i enter it? SD channels are working fine with manually PIDs.
Thanks!
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
Thanks!
On the TM5402HD it is at the bottom of the section where you add the pids, Menu, Edit Channels,Add Channels.
If it is not there on the Dr.HD then we need someone who has one to let us know.
nml
Gibertini 1.5 dish, Gibertini 1.2 to motorize, Funke 1 mtr motorized.
VU+ Duo,3 dreamboxes,2 Foxsat hdrs,, 3 digiboxes and relook 400s.. Satcatcher mk4 Nit, Satlink 6908 and an old Lacuna.
Granada, Spain
I have got a couple of enigma 1 boxes in the back of the cupboard and I recollect that you can enter the pids. Is it worth dragging them out, has anyone tried it or would it be a problem with frequencies?
nml
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
Just an update, BBC One is no longer BBC One London. It was BBC One Network when checking on the local opt outs diuring the news. Cut to the BBC Holding card of the BBC logo moving
huve
Faval SH 100, Mystique SaTiX-S2 Sky V2 USB, GI 110 cm, Inverto Black Ultra single
Helsinki
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
my TM5302HD wont download the channels anymore even though the signal is booming in at 97%SS 92%SQ
nml
Do the receivers do DVB-S2?
If not forget it.
Robinson74
Motorised dish 45E - 30W, Clarke-Tech ET9000
Poland
Does this script help in enigma boxes? You propably have to read the hole thread to to know how to use it.
http://openpli.org/forums/topic/266...elsat-a-big-challenge/?view=findpost&p=377814
I can't test it myself. This bird is behind a tree in my location.
It does work for me but only in the long mode, which means no sound on HD channels.
I would appreciate it if someone with ET9x00 could test it. Short mode does not work for me on ET9000 with OpenPLi.
Apparently it does work correctly on 7020HD if a proper demux number is used in the script.
margusten
Lat 59.40 Lon 24.68
DR.HD F15, TBS-5925, Dream 800PVR, GM TripleX
Aerial AS24 polarmount 95E - 13E Ku+C, fixed 3M 28.2E, 27.5W ...
Estonia
New channels on but no picture yet.
BBC Three HD and CBBC HD
Deso
Fuerteventura/UK
Message for Chelsea Baz, did you get my PM?
marjanen
Vu+ Uno
Finland
tothbros
Budapest, Hungary
so looking at the future without 1N, my only chance for UK PSB is this - however uncertain...so do i gather correctly that the two best receiver options are the technomate 5402 hd and dr.hd...with these two receivers - patched, i assume? - and a bit of googling, i can get those channels from this position - for the time being, until they choose to tighten the encryption method - is this right?
BLUEPLATINUM
Maspalomas, Gran Canaria
The Technomate works flawlessly and doesn't seem to be affected by changes in the transmissions (scrambling the PMT, etc.) that cause problems for other receivers.
Does anyone know if there is a PVR receiver that is equally reliable? - Being used to Sky HD I will have difficulty adapting to not being able to record programmes in the same fashion. Lack of EPG will also be a problem I think!
BLUEPLATINUM
Very good news. Demonstrates their continued commitment to this platform.
BlindFaith
TBS 5925
BBC THREE starts at 19:00 ;)
Though PMTs are still scrambled, it's straightforward to predict the ES_PIDs
e.g. CBBC HD
ServiceID = 18112 - CBBC HD
PMT PID = 7100
V_PID -> PMT_PID + 1 = 7101, stream type: H.264
A_PID ->PMT_PID + 2 = 7102, stream type: AAC
PCR_PID = V_PID
Alas these pids are missing :(
