The satellites.xml that was included in the firmware image contained this:
<sat flags="1" name="Astra/Eurobird (28.2E)" position="284">
Changes to satellites.xml will only take effect when doing a new scan I guess?
Will the lists with favourites suffer after a rescan?
I have created quite a few and rebuilding them would be a major pain in the ....
If the updates are included in the favourites without ruining too much I'd like
to test this now.
When scoring the new channels file satellites.xml the erroneous position who are favorites / bouquet is lost.
You should make all the position 28'2 ° East.
If the monitor is large or you work with 2 monitors
you can open two DreamboxEditor and work in 2 different files, to see the changes, it is more comfortable. ;)
In this case is not valid copy of each other, remember that the reference channel is different.
I don't understand how Waveguide has got something different. Settings are universal across all boxes. If not how could we share them. Also service reference is used for picons, so that wouldn't work either.
Now remark as a reference channel is generated, it is easy to understand the error.
I had the bad habit of generating hand / calculator before DreamboxEdit implement copy or view information channel on the tuner to the picon.
Just rename the picon with the new reference channel, fixed issue, that's easy.
http://satellites-xml.org/
http://satellites-xml.eu/
In these 2 pages that generate the relationship of satellite and tp's, one uses the database LyngSat, for better or worse and the person responsible for putting the data makes mistakes, is not the first nor will be the last.
PS:
Al meter el nuevo fichero satellites.xml se pierde los canales de la posicion erronea que esten favoritos/bouquet.
Tendrias que hacer toda la posicion 28'2ºEste.
Si el monitor es grande o trabajas con 2 monitores
puedes abrir 2 DreamboxEditor y trabajar en 2 ficheros distintos, para ver los cambios, es mas comodo.;)
En este caso no es valido copiar de uno al otro, recuerda que la referencia de canal es distinta.
Ya comente como se genera la referencia de un canal, es facil de entender el error.
Solo con renombrar el picon con la nueva referencia de canal, tema solucionado, eso es facil
Tenia la mala costumbre de generarlos a mano/calculadora antes de que DreamboxEdit implementara copiar o ver la informacion del canal en el sintonizador para realizar el picon.
En estas 2 paginas que generan la relacion de satelites y tp's, una de ellas usa la base de datos de LyngSat, para bien o para mal y la persona encargada de meter los datos comete errores, no es el primero ni sera el ultimo.
PD:
