angoodwi
- Feb 6, 2014
- Age
- 46
- 105cm, 3 x LNB, Dreambox 500d
- Prague, Czech Republic
Now here in Slovakia despite getting them earlier this morning I have lost all the bbc channels ! Still getting c5's which Is very strange as I understood they had all transfered over. Also 5*+1 is missing ?
Channel 5's channels are on 2F and are not moving. Only the BBC and Sky UK spot transponders moved last night to 2E. ITV and Channel 4's transponders will move shortly.
5*+1 was replaced with Channel 5+24 at the start of the week.
I think it is a bit strange, maybe that means 2E is even tighter than 2F?
Hello from Greece , South Greece , Crete IRAKLION .
I can receive 2F 2A south and 2E Europe Satellites.
I have 1,85 Mabo dish with vu + solo2 receiver.
Uk beam 0,00 db. No channels clear
Eurobird 28A 2,50 to 4,00 db Some channels clear
For 2F I have 8,5 db to 9,5 db. All channels clear
For 2E I have 7,0 to 8,0 db. All channels clear
For 2A south 12,00 to 13 ,00 db. All channels clear
For 2A north o,00 db. No channels clear
Hi Alistair , I've seen a reception reports from an other site that says a 1m is good enough to pick up the spot beams from 2E and 2F(only SD was mentioned) in the Milan area.Maybe a better LNB(the one in the report was an Inverto,I like Opticum Quads especially if the cable run is long),decent cable or fine tuning the alignment might help.CheersI think it is a bit strange, maybe that means 2E is even tighter than 2F?
Campoli Appennino, Lazio, Italy. 1.25m offset dish with black ultra quad lnb.
Spot beams of 2F and 2E - not a trace of a signal.
PE beams of 2F and 2E - no problem whatsoever, strong signal on all transponders.
2A North beam still breaking my whatsits! Get those channels on 2E please!!
2A South beam - perfect signal.
