31E Avanti mux
Archive-8
Tbs Card has just found this:
1=10958,H,45000,12,21,|9.8 (8.5) dB
2=11218,H,45000,12,21,|14 (12.7) dB
3=12068,H,45000,12,21,|13.9 (12.6) dB
But no picture, I guess it must be data of some sort.
Archive-8
Very good scopus, haven't tried Band B with mine.
@Chris1979
Check out the http://www.satellites.co.uk/forums/threads/the-directv-sl3k4nr1-03.162534/ thread, plenty of info there for using one those LNBs. The '03' version seems to be the more sensitive one we find. There's usually one or two available from the US. Search for 'sl3k4nr1-03'
I will have a look at ebay tomorrow for one. Thanks for your help.
How do you work out ka freq to ku freq? Is that as easy as the other way?
Is that the direct lnb just strapped on the dish? If so I might have to get one :)
I made a bracket Chris, lowered one of the boom arms on my Channel Master 1.8, so it sits offset by 4 degrees at the side of the Ku, works well.
Find KA LO Freq - KA Freq. Add result to KU LO Freq.
Example:
(21200 - 20035) = 1165 + 10600 = 11765
I was one digit out in previous KU to KA example. 20045 should be 20035 :-doh
ACM AOL feeds Chris. Been there for ages.
Archived-1
Persona non grata
uk
AVANTI One showing Mr bean holiday (next on is Crank)
AVANTI Two Animal Farm (no EPG for next programme)
AVANTI 1HD Test card (EPG showing Frost Nixon)
AVANTI 2HD showing The life of David Gale (no EPG for next programme)
Archive-8
Happy hunting, I am just about to go and tweek my dish/ remove an lnb, & line up the brackets.
The two Avanti HD channels are now coming up as encrypted.
That cured it..........
Still OK here.
