Advice Needed On a new actuator please
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
I am unsure where they get the shipping prices from, I would probably get a big dish shipped for less.
MA-834138543-24B
(24” BALL SCREW WITH TUBE BOOT, REED SENSOR, 36VDC, LIMIT SWITCHES, HD CLAMP,
QTY:1
COST: $225.00
SHIPPING COST: $180.00
TOTAL: US$405.00
:eek:
Wow.....I can understand the damage/insurance side worry but for a package that size........thats some cost!!
Hope you can sort Martin. I am now on the hunt for a polar mount + accessories for my own 1.8 PF.
Archived-1
Persona non grata
uk
Thank you Lp, are you looking for new/used please ?, I will give you a nudge if I see something :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Well as per my postings, have a 1.8 PF Famaval and following comments....'you must have a polar mount'.....agree, but I have enjoyed the manual introduction of the larger dish especially on C-Band!
Like yourself...prepared to pay for quality but locating the item and its delivery cost is an important point.
Thanks for your guidance M. :-applause
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Had no reply from Famaval or Marrafa on polar mount purchase or suppliers / shops so no further forward with this.
Archived-1
Persona non grata
uk
Great... now I'll HAVE to buy a ball screw jack :( Thanks for nothing, Martin :p :D
Seriously, though, I am glad that there are some good jacks out there. There isn't a single jack that I own that I am totally happy with due to play, noise, unreliability etc. and is the reason why I favour H-to-H motors to jack driven mounts. If these are as good as I am led to believe they are then I'll be happy.
Archived-1
Persona non grata
uk
:-lolI can only let you know when I get one Alex :), I've located the one below it says its $299 but when you change the currency to uk it comes up at £150.89 for some reason, I have emailed the shop to check there delivery price.
http://www.thesatelliteshop.net/cba...h-satellite-actuator-jack-819b24ck-p-105.html
Venture got back to me with a better delivery rate but still to expensive.
Priority Mail International would be $140.00
Paul R. Hollis Venture Mfg. Co. 3636 Dayton Park Dr. Dayton, OH 45414 937-233-6832 ext. 310
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
You would think a company like Red Apple for example ...would realise there is a market for the higher end actuator ...and that importing them and re-selling would be profitable ?
I'm surprised and frustrated there isn't a UK vendor.
Maybe it's because a Von Weise wouldn't fail so quickly ..thus the market wouldn't continually churn..
Why sell 1 when you can sell 10..
..or am I being too suspicious..?
rgds
VS
Costactc
Canada
Costactc
Canada
I've bought many things from Rick Caylor like azbox receivers, he's an upstanding guy.
Archived-1
Persona non grata
uk
Many thanks for those words they mean lots to me, feeling comfortable with who I am dealing with is half of my battle ordering one :).
Archived-1
Persona non grata
uk
What size actuator is recommended for inclined orbits please.
Costactc
Canada
Just tell him Costa from Canada sent you, we have spoken several times as I have ordered at least 7 times from Rick.
Costactc
Canada
What difference would an inclined orbit make when it comes to actuator size?
Archived-1
Persona non grata
uk
My mount will be made to track them, it will only be moving up and down a bit so maybe a 12 inch ?.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
Will the 12inch be strong enough to pull your dish up and down ? is it taking all the weight?
Archived-1
Persona non grata
uk
You can buy them in size and pulling/pushing power, but yes many thanks that's something to check,
I still need to know the ideal length please, then I can get one with enough humph.
purplemarina
hampshire uk.
I used 18 inch on my inclined 1.2m, only because i had a spare. i would say you only need an inch or two max of movement, most sats are only a few degrees inclined up or down.
My small 10" one (er... the actuator, that is) is fine for adjusting declination on my 1.5m dish. It's in tension, so I have a short piece of rope safeguarding it in case it decides to fail. The dish is quite light though and it has no problems moving it up and down a couple of inches.
The 1.8m CM is a different beast though - much heavier, so I would want something beefier...but a 12" should be ok. And if it's used in compression mode, then there's far less chance of failure.
