Zeonbud 12188H on 4.8E
MCelliotG
Thessaloniki, Greece
It seems that both streams 10 and 20 on 12188H are now T2-MI, since the channels don't download directly on my receiver as they used to a few days ago!
Running 4T2 analyzer shows me this
Now, if this is an indication the remaining two streams on 12341H might soon pass on T2-MI as well! Ouch!!!
Adam792
Cheltenham
I had multistream 10 on 12188H working the other day using the T2-MI command line tool in Linux -
GitHub - newspaperman/t2-mi: This is a commandline T2-MI baseband frame extractor
All the same channels as before, just encapsulated in T2-MI. The channels were breaking up though. I don't know if this was the tool or because my signal level wasn't good enough though!
PERSHIY (UT-1) seemed to be test bars only as well. I've definitely seen this transmitting normal programming when it was regular multistream without T2-MI.
Sent from my iPhone using Tapatalk
BlindFaith
TBS 5925
Both multiplexes can be decoded fine but both show quite a few errors though SNR is high enough. I rather use the re-streaming option to Transedit :)
MCelliotG
As T2-MI they both tune fine and show channels as expected, the question is: why did MIS 10 pass to T2-Mi now after all this time? Should that mean the other two 30 and 40 will pass as well?
Adam792
Cheltenham
I'll have to have a go with 4T2 Analyzer in Windows then!
The DVB-S2 card wasn't reporting any dropped packets or corrupted frames so it must have been something to do with the stream decoding on my system.
MCelliotG
To be fair, sometimes some MIS channels do break up in my system as well and have to reboot the card from power, but I have the USB version. You can try MIS 20 and see if you have breakup on this package as well!
BlindFaith
TBS 5925
I have USB (TBS5925) as well. You can record the single pid stream error free and then take 4T2 for offline decoding. The extracted elementary streams show the same number of missing packets. The culprit has to be at or before the playout :rolleyes:
Adam792
Cheltenham
I get errors using the Linux T2-MI tool on both MIS 10 and MIS 20.
The normal multistream channels on 12341H (MIS 30 and MIS40) play perfectly with no errors, and before the change to T2-MI MIS10 played fine as well on 12188H.
The SNR seems fine and the DVB-S2 card is not dropping any packets.
