My satellite setup
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
John Pykett
Persona non grata
Anybody remember when Manhattan was just a normal sat receiver make? I remember them, Force and Echostar, names gone almost now.
Sent from my thl_T7 using Tapatalk
manhattan is still around they have a website you know? manhattan-tv.com
John Pykett
Persona non grata
Yes motorised. picture was example, unsure where that ones pointing but reception will not be good.
what is bad about the reception?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
How far back do you want to go mate ..
Welcome btw ..
-----a potted history----
All the way back to the first dedicated TV service in the UK ..
Back when Sky was BSB ...and broadcast in circular polarisation from MarcoPolo ..
Back then it was of course Analogue ..
Other services were available of course but these were not UK specific ...and required large dishes and motorisation as a minimum ..
Back then it could easily cost you a couple of grand for the gear ..
Only when BSB started up and fixed dishes pointing at Astra 19.2 around 90cm did it become of economic and practical interest to the masses.
Really sat as we know it today ..re digital went through a few manifestations such as Dmac ...until a standard was accepted ...
In the UK this was Videocrypt ..
All change after that ...That phase of satellite distibution had more in common with Analogue ..
I suppose you could call it encrypted Analogue ..
True digital is what we have today our arc slot being 28.2 E (Encyption format NDS/Videoguard)..though Dmac and D2MAC not used by the UK _were_ digital formats in their own right..
The rest as they say ..IS history ..
John Pykett
Persona non grata
Welcome btw ..
i got question, why was analog satellite reception better than digital satellite reception?
I don't know if the analog reception was better then now.What was important in the analog period was that you saw the image even if the signal was weak.Then you shouldn't have locked this signal.It is true that with many "fleas".While now,in the digital era,you can't lock than the useful signal.
John Pykett
Persona non grata
true but now if signal is weak its get distorted and stuff
Now we have BER in place of "fleas":)
John Pykett
Persona non grata
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
John Pykett
Persona non grata
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
also i wonder why some channels on freesat have weaker quality than others is it because of spotbeam?
Based in the U.K. with your beams I would not have thought so....here different matter eg:- 12129 V 27500 2/3 on Astra 2E U.K. spot beam....not so easy!
There is indeed variation, even with three fairly new birds in place. But not enough to trouble anyone in the UK, in practical terms.
Precise location and attitude of each craft, HD or SD, FEC, Polarisation etc all seem to have some minor effect.
Was a lot worse with the ailing birds a few years ago!
And then there is the question of LNB performance across the band .... definitely not flat ..... and also compatibility between LNBs and Receivers. Hard to quantify, though but.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Good morning, hope all is good with you.
Yes, seems not so long ago Astra 2D was seen as a swear word by many here!...............more than ever, skew is vital for optimum reception now.
John Pykett
Persona non grata
ill check that frequency on freesat to check quality
John Pykett
Persona non grata
why does those things you said effect signal quality such as fec and polarisation?
John Pykett
Persona non grata
my satellite setup doing good in 2017!!!
Be safe. View attachment 100052
im back on my post to say that my satellite setup is still doing good in 2017!! :)
Doing good what ?
