Retired human
- See signature
- North Somerset
Just to follow up on this - very disappointed with the quality of the unit. Already seeing rust forming after just a few months under the flaking paint. And much rusting inside.Yes, another issue I've found is that there is no drain hole at the bottom of that weld so all rainwater is nicely being collected inside ready for rust to take hold. This is what I had from Dave @ SSS on the matter...
Hi Alex
The metal is that thick I think it would take many years to be a problem
However, an Aerosol of Hammerite waxoil sprayed in should sort it out
this is what you put inside the chassis of a car
Available from Halfords
thanks
Dave
For the price we've paid, we should NOT be worrying about these things - it should have been made out of stainless steel or properly galvanised.
Where's the "superior" British manufacturing gone? This one almost looks like it was made in China!
Time to order bits to make my own adapter.
